Results 1 to 9 of 9
Thread: Baseline DE filter pressure seems high
    May 2008
    Tucson
    30
    I have an old Hayward 1.5HP Superpump, 2" plumbing, and a Hayward 4820 DE filter with a cartaker system with 1.5"? plumbing. My baseline pressure with clean filters and new DE is around 28 psi. This seems awful high compared to most recommendations on this fantastic forum. Does this pressure seem right?
    ~25000 gallon free-form in-ground plaster pool located in Tucson in full sun
    TFT-100 Test Kit
    Hayward DE4820 filter
    Caretaker system
    Hayward 1 1/2 HP Super Pump
    Mar 2010
    Spring, TX
    1,082
    Re: Baseline DE filter pressure seems high
    Do you know how old the pressure gauge is? Not sure how long these last but it could have gone bad.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    May 2008
    Tucson
    30
    Probably going on 10 years old. It registers a pressure change so I know when to backwash but it just seems really high.
    TFT-100 Test Kit
    Caretaker system
    Feb 2008
    Denton, TX
    5,061
    Pressure gauges that come with most filters are rather cheap items and can be prone to failure. If they are suspect, they are very simple to replace.
    When your pump is turned off, does the needle go to zero?
    May 2008
    Tucson
    30
    Very good point, it does not go to zero. Are they just standard pressure gauges you can get at like an autoparts store?
    TFT-100 Test Kit
    Caretaker system
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by bhodge
    I get mine at a farm store. You can get a larger gauge that's easier to see, but make sure you get no more than a 0-60psi gauge so that pressure changes are more noticable.
    May 2008
    Tucson
    30
    by autoparts store I meant home improvement store, multitasking no working so well for me today
    TFT-100 Test Kit
    Caretaker system
    May 2008
    Tucson
    30
    I see your in Indiana so I assume you get everything from a farm store!
    Just kidding, thanks for all your help.
    TFT-100 Test Kit
    Caretaker system
    Pool stores nearly always have pressure gauges, usually under $10. Home improvement stores around here don't carry them, but they do in many areas where pools are more common then they are around here.
