Thread: Confused about IC20 vs IC40, and automation
    Guys,
    My pool gets installed in a couple weeks and I am struggling with the last couple points. I was thinking of getting the Pentair EasyTouch 4PSC-IC40 figuring that the IC40 would be good considering everything I was reading. Questions are as follows:
    1.) Since it is 13k the builder was offering a IC-15 for 775.00 I figure I would upgrade to a IC-40. I am in the Midwest (STL) is that a good move?
    2.) Should I even buy the Pentair EasyTouch 4PSC-IC40 I am not installing a in-ground spa? I am installing a portable hot tub. If not what do you recommend for automation I am using a Polaris 280 with booster, SR Smith Turbo Twister, Sta-Rite SR333NA Max-E-Therm and LED Lights along with the other equipment listed in my tag.
    Carla
    11K gal, in-ground 15'x33' San Juan Fiberglass, Pentair Whisperflo 3/4 hp pump, Pentair Clean & Clear Plus Filter CCP320, Pentair Inteliclor 40 SWG,
    Dec 2009
    Central Massachusetts
    2,690
    Re: Confused about IC20 vs IC40, and automation
    Get the IC-40. The IC 15 would be barely big enough for your 13,000 gallons and even at that, the run time would be almost 24/7 to keep the FC correct. An IC20 could work, but fora few bucks more, go with the IC-40. i have one on a 14,000 gallon pool. It makes plenty of chlorine with a minimal run time.
    I would recommend getting the automation controller. It makes ontrolling the IC-40 much easier, and also acts a pump timer. You will like it.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
