Thread: Testing TA How Red???
    Apr 2010
    Fairfield, New Jersey
    22
    Hi
    When doing the drop test for TA am I done at the first turn of color (usually pink) or do I keep going for a more reddish color???
    Best regards,
    Ken
    13K gal, Vinyl, 24' x 52" AGP, 1 HP pump, sand filter, 75 GPM, Chlorine
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Testing TA How Red???
    I get sort of a magenta color - not really a true red. just make sure it stays pink and doesn't turn sort of grey again.
    You add drops until the color starts changing, then continue adding drops as long as the color continues changing with each drop. When you add a drop and the color doesn't change you are done and you do not count the final drop (which didn't change the color).
    The particular shade of red doesn't matter.
