Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Sand filter not filtering.
    Jun 2008
    MOBILE, AL
    65
    I have a sand dollar sand filter and it does not seem to be filtering properly. It is two years old and I have never done anything to it other than the normal backwash and rinse. I vacuumed the pool the other day and it was perfect, I went back out the very next day and all of the sand I vacuumed out seemed like it was back on the floor. It may not be all of it but most of it is. I saw in another post where it may be channeled and to hit the side of the filter with a rubber mallet but when I tried that dirt started coming out of the return. Any ideas what may be happening and what I should do? Thanks for your help.
    24' AG, 52" wall ,resin with 1Hp pentair pump with sand dollar sand filter. Hayward aquatrol salt generator
    Re: Sand filter not filtering.
    Dirt coming out when you tap the filter with a mallet and having dirt come out confirms that the filter is channeled. You should follow the directions in this post to clean and resettle the sand bed inside the filter.
    Jun 2008
    MOBILE, AL
    65
    I will do that this weekend. It looks like I will have to cut the PVC pipe on each side of my valve on top of the filter, is there any way to avoid having to cut each time I have to do this?
    When you cut the pipes, install unions. Then the unions can be disconnected and the filter opened without any further cutting in the future.
    South Central NJ
    3,192
    Installing flush unions will enable you to open at will.
    Scott
    Owner of - PoolGuyNJ LLC
    Jun 2008
    MOBILE, AL
    65
    Great. Thanks for the help. This site is awesome.
    Jun 2008
    MOBILE, AL
    65
    Do you mind showing me a link of what you mean by a flush union? I just searched Lowes.com and did not get any results for that.
    A flush union looks just like a regular union on the outside. The only difference is that you can push a piece of pipe all the way through it, there isn't any lip on the inside that stops the pipe when you are inserting it. If you can find flush unions they are easier to install because everything can stay in exactly the same position it was originally and you only need to cut each pipe once.
    Installing regular unions can be done without too much work if you can't find flush unions. Places like Home Depot or Lowes aren't likely to have flush unions. To use regular unions you need to cut the pipe twice, so there is enough room for the width of the inner lip of the union.
    Jun 2008
    MOBILE, AL
    65
    Ok well I got my unions installed and removed the head of the filter. When I look inside at the sand I dont see any channeling or clumps of sand, its pretty dirty butI am flushing it out with a garden hose as we speak. When I look inside the filter what should I be seeing other than a stick of PVC and sand? Any ideas to why it would not be filtering as it should?
    Jan 2009
    Cupertino, CA
    1,966
    Channeling is not always visible, and clumps can be down where you can't see them. Put your hands right in and feel around for clumps, break them up if you find any. At the very least you'll be swishing the sand around and any channels will be broken up as it resettles.
    --paulr
    BBB "Intermediate Swimmer"
    Jun 2008
    MOBILE, AL
    65
    I stuck my hand in and did not feel any clumps so I got the hose with a nozzle on the end of it and stuck it down in the sand and moved it around until the water running out was clean.I dont know what else I can do. I had a hard time trying to get my hand further than 3 inches in the sand due to the pvc being in the way.
    Jan 2009
    Cupertino, CA
    1,966
    Sounds like you've done what you can--the hose would have helped too--so put it all back together and see if there is any improvement.
    --paulr
    Jun 2008
    MOBILE, AL
    65
    Well I put it back together and vacuumed all of the dirt out of the pool only to find the next morning the dirt was back in. Now what?
    30,419
    Do you know for certain that it's dirt/sand and not dead algae? Can you post a set of test results?
    Jun 2008
    MOBILE, AL
    65
    I am certain its not algae, I have never had any type of algae in the pool. I guess I need to find some wood to knock on now.
    FC=5
    CC=0
    ph=7.5
    T/A=60 in process of raising to 70
    CYA= 30
    Jun 2008
    MOBILE, AL
    65
    Well I went and bought all new sand last night for the filter. Cost me a whopping $28, I was suprised. Now the question is whats the easiest way to change it?
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    If you have a shop vac, you can vacuum the old stuff all out. That would be the easiest. I did that and used a wheel barrow to haul it to the alley that is graveled and dumped it right in the alley. I also used it on a paver walkway to this alley.
    Shop vac was quick, simple and fast. Then it gave me a chance to inspect the laterals and all the tubing as well. I would suggest that you replace your laterals since you are replacing the sand. I ordered mine online. It came in an assembly kit as I had the main tube broke as well so I bought the whole inner guts in one shot.
    This is the second year running and the pool looks sweet. Take a look in my sig for pics!
    I am sure some of the professionals will chime in soon.
    good luck!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    30,419
    After you get the sand changed and if it still leaks, make an inspection of the multiport valve. Since it's not algae, that's where I would look next.
    Jun 2008
    MOBILE, AL
    65
    If it was the multiport valve how hard is that to fix? Is it expensive? I have a feeling that may be the problem since when I had the valve off everything looked good in the tank and of course I always have the best of luck
  20. Back To Top    #20
    30,419
    Most frequently, it involves replacing the "spider" gasket......should certainly be less than $20.00
