Thread: Cal-Hypo Tablet use in Rainbow 300?
    Apr 2010
    Houston, TX
    i have a Pentair Rainbow 300 feeder designed for 3" Trichlor tablets and would like to use it for 3" Cal-Hypo Tablets. Has anyone done this or see any problems? I don't want to add chlorine every night or go back to using Tri-Chlor.
    1996 18K IG gunite, 4 Spray Heads, SPA with Waterfall & Fountain. 06/09 New Plaster with Gorgeous Copper colored Slate.
    Pentair FNS48 DE filter @120 gpm. New AO Smith Hi-Eff 1.5 Hp motor driving WhisperFlo WF28c 105 gpm Pump and
    3/4 Hp Booster for Pentair JetVac in-floor cleaner. Laars Lite 400K Propane Heater.
    Jandy Aquallink RS4 controller. Chlorine. Taylor K-2005 Test Kit.
    Re: Cal-Hypo Tablet use in Rainbow 300?
    That really won't work at all. Cal-hypo dissolves very quickly compared to trichlor. Anything designed to work with trichlor is going to feed in way too much water and the cal-hypo will all end up in the pool in short order. Also, you never want to put cal-hypo into a chlorinator that has held trichlor in the past.
    There are a few chlorinators designed to work with cal-hypo, but they are difficult to find and don't seem to be reliable long term.
