Thread: Digital Testers
    Mar 2010
    Spring, TX
    1,082
    Digital Testers
    I was looking here
    http://www.lesliespool.com/browse/Home/ ... 000:400020
    I am the most interested in the aqua check one for pH.
    And noticed they have these testes for all the test that can be done. How reliable are these things? The one I have the hardest time with is the pH one as sometimes the shades are so close together it makes it hard.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Digital Testers
    The AquaChek TruTest Digital is not at all precise. There are inherent problems with test strips. No matter how well the electronic portion can read the color, the color isn't especially precise to begin with.
    Stay away from the E-Pool, not only does it lack precision, but a high percentage of them were failing last season after on a few weeks (or days in some cases).
    The ColorQ is quite good, probably the best of what you can get for under $200. It's PH, FC, and CC readings are excellent as long as FC is below 10 and the CH level isn't too high. Its other tests are not as precise, but mostly usable.
    The pH Testr 2 and pH Pocket Pal are alright as long as you get the calibration solutions and calibrate them occasionally. The pH Testr 2 is much easier to calibrate.
    Mar 2010
    Spring, TX
    1,082
    Re: Digital Testers
    How high is too high for CH on the ColorQ one you stated?
    Re: Digital Testers
    CH levels starting around 500 and higher have been causing problems for several of the tests on the ColorQ. I notice that the spec for the ColorQ now lists a higher CH test limit, so there may have been improvements to avoid CH interference at higher CH levels, but last I heard there started to be issues around 500.
