Results 1 to 7 of 7
Thread: Pentair IntelliChlor IC20 or IC40?
    I am self installing a Viking St Thomas 13,700 gallon pool. I will be installing the Pentair IntelliChlor system. I figured I needed the IC20 since my pool is under 20,000 gallons. Is that correct, or is there a reason I need to move up to the IC40?
    Nearly done self installing:
    Viking "St Thomas" in-ground 13,700 gallon fiberglass pool (14' x 32' x 7') / Pentair VS-3050 pump / Pentair Clean & Clear 420 sq ft Cartridge filter / Pentair EasyTouch 8 automated system / Pentair Intellichlor IC-40 SWCG / Pentair Kreepy Krauly SandShark suction side cleaner / Pentair Intellibrite LED pool light / Jandy deck jets (x5)
    Dec 2009
    Central Massachusetts
    2,690
    Re: Pentair IntelliChlor IC20 or IC40?
    An IC-20 would work, but the percentage would have to be set higher than an IC-40. The prices are pretty similar between the two; i would go with the IC-40. My pool is around 14,000 gallons and I have an IC-40. I run it ~2 hours a day and keep my FC at 5 ppm. Everybodies pool is different, but the rule of thumb is get the biggest SWCG you can, within reason, obviously.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Where are you located? There could be a few variables that could contribute to the decision making process, like your fill water chemistry...
    Dec 2009
    2,690
    IC-40, trust me. Couple hundred dollars more, well worth it. not many, if any chemiastry considerations for the size of SWCG to get, IMO.
    11,969
    My thinking was if your fill water is high in TA and CH and you are in an arid area and have to frequently add water you'll be in a constant battle against drifting PH therefore the larger cell size would be well worth the additional funds so that you can run the unit less.
    Southern California
    Geez, I'm glad I asked. I will consider the IC40 instead.
    Dec 2009
    2,690
    Quote Originally Posted by frustratedpoolmom
    Actually, thats not a bad consideration, either. The IC-40 should make plenty of chlorine for his needs and cut the run time quite a bit.
