Thread: Can I add salt to lower CH?
    Probably a dumb question; but my mind thinks up these crazy ideas while I sleep - or when I am in the shower.
    Follow the logic if you dare. For centuries people have added salt to water to soften it. You can still buy bath salts. I have a water softener at my house that uses salt to condition the water. Salt makes water feel slick and soft.
    If the above is true, could I throw some salt in my pool and lower the CH, or is it totally unrelated?
    19,000 gallon, irregular kidney shaped, plaster pool surrounded by (8) cypress, (1) oleander, (3) palm trees, (2) unknown shrubbery
    Pentair Tagelus 100D sand filter, with fresh #20 silica sand, and WhisperFlow 3/4 hp. full rated pump
    Innovative Pools controls with digital timers and remote light switch
    Hayward pool sweep with new gearbox A-Frame & turbine, and pods
    TFP's resident Pool Fool :)
    Feb 2008
    Flower Mound, TX
    Re: Can I add salt to lower CH?
    Not a dumb question! But no, adding salt to the pool won't remove calcium from it, although it can improve the "feel" of the water.
    The reason that salt is used in a water softener is because it functions as a replacement for the calcium in the water. Via reverse osmosis, the calcium ions in the water are exchanged for sodium ions inside the water softener.
    10K gallon IG gunite with waterfall; Pentair CC320P filter; WhisperFlo 2 HP pump
    TF Test Kits - Pool Math - Pool School
    "It depends."- JohnT
    Good question, and shows you're thinking (and lets me know I'm not the only one who thinks in the shower!)!
    Salt is also corrosive above certain levels (well, it is always slightly corrosive, but more so above certain levels ), so you want to watch that!
