Results 1 to 10 of 10
Thread: It's PURPLE!!!
    Memphis, TN
    7
    It's PURPLE!!!
    Monday-Beautiful blue sparkling clear water. Just getting into the swing of pool season again but very proud of BBB 48 hours after removing cover. Still running filter 24/7.[attachment=2:2k6oblre]bluepool10.jpg[/attachment:2k6oblre]
    Tuesday evening thought the sun was flashing off of it funny as it looked purple. Went out in the backyard and lo and behold it is purple! The picture doesn't do it justice it is purple! Sparklingly clear but purple just the same![attachment=1:2k6oblre]purplepool1.jpg[/attachment:2k6oblre][attachment=0:2k6oblre]purplepool2.jpg[/attachment:2k6oblre]
    Here's the particulars
    FC 2.0
    TC 3.0
    ph 7.0
    TA 50
    CYA 0.0
    Water temp 65
    Obviously will be raising chlorine to 12 or better and getting some cya in there tonight. Should I be concerned how low the ph is while adding the cya? Purple yall! Anybody seen this?
    HELP!!
    29,000 gal IG vinyl
    Hayward sand filter
    Nautilus w/ booster pump
    BBB believer!
    Dec 2009
    Central Massachusetts
    2,688
    Re: It's PURPLE!!!
    How much water did you add from the hose to top off the pool? Ever had this before?
    Purple is usually caused by manganese metal in the water.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Toms River, NJ
    151
    Re: It's PURPLE!!!
    I would raise the pH as CYA is acid and will slightly lower your pH. The effect of the CYA is small, but at 7.0 I wouldn't risk it.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Re: It's PURPLE!!!
    Are there any teens that might have added dye to the water? Dye will go away over a couple of days if you raise the FC level.
    Manganese, on the other hand, will get worse (for now) if you add chlorine or raise the PH. Coloring from manganese will go away if you add sequestrant.
    Memphis, TN
    7
    Re: It's PURPLE!!!
    Thanks for the help. Teens around here would never do something like that! I guess it's a possibility but I have dogs so I'm leaning toward no on the kids. I'll get the FC and ph up and see what happens.
    29,000 gal IG vinyl
    Hayward sand filter
    BBB believer!
    Feb 2008
    Denton, TX
    5,061
    Re: It's PURPLE!!!
    You might take a sample of your pool water to a pool store and have them check for metals. I wonder if a pool store would even test for manganese? Don't really hear about that one much.
    Re: It's PURPLE!!!
    You can test for manganese with a Taylor K-3221 kit, but it is very expensive. I have also seen test strips for around $30.
    Dec 2009
    2,688
    Re: It's PURPLE!!!
    My bet is still with the manganese, but I cant figure out where it might have come from except maybe the top off water. If it were mine, i'd hold off on raising the pH much. If it is metal, it could make it worse. My opinion is get some CYA in the pool, maybe increase the ph to 7.2, and go get a couple quarts of a phosphonic acid based sequesterent. Proteam, Jack's magic, or even the HTH brand from Walmart will do. Add 1 quart per 10,000 gallons of water, run the pump overnight, and see what happens. If it's not metal, it wont hurt anything, and if it is, it should clear or be noticably better by morning.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: It's PURPLE!!!
    Last summer you had yellow water.
    Looks like you will continue to have issues with metals unless you make sure to add the maintenance doses of sequesterant.
    I also suggest you try sequesterant first.
    That purple is pretty, but as you say, not for your pool
    You're done SLAMing when:
    Memphis, TN
    7
    Re: It's PURPLE!!!
    Here's the update. I had a crisis at work and didn't get to add anything in that night. The next morning it was back to blue with some settlement on the bottom. Not much just a little. So basically I did nothing and it corrected itself. I have since raised the FC and the ph and am working on cya but have a beautiful pool again. Leaning towards the prank thing for it to have happened the way it did. Now if I could just get the temp up! Thanks for the help!
    29,000 gal IG vinyl
    Hayward sand filter
    BBB believer!
