Results 1 to 14 of 14
Thread: Skimmer socks rule!
    Jul 2009
    Eastern NC
    26
    Skimmer socks rule!
    My pool is full of beautiful, sparkly (alhtough still a bit chilly) water. I've been waging a battle with the tags from both an oak tree and pine tree that aren't directly beside the pool, but close enough to be a nuisance. I finally put an old knee-high in my skimmer Sunday evening to try to catch the little bit of film that's on the top of the water. When I checked it after work yesterday, I was amazed (and a little bit disgusted) by what I found ... good grief! It was probably a palmful of tan, spongy gunk which I am assuming is pollen. I tossed that knee-high & replaced it with another. Is it crazy that I'm looking forward to checking it out in a couple of hours?
    Thanks to FPM & others who recommended using the skimmer sock. It's been a terrible pollen-filled spring thus far in NC!
    24' x 52" AG round - 13,500 gallons - 2hp 2 speed BaquaPure pump, Pro Clean cartridge filter, TF-100 Test Kit
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: Skimmer socks rule!
    I love them too! I usually only use them in the spring. Just make sure to check them, they can sure clog the ole skimmer up.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    My local Walgreens sells Queen-sized knee-highs for 59¢/pr or 2 pairs for a buck. They work good - it's amazing how much fine **** isn't clogging the DE filter.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I get the knee highs from Wal-mart - 10 pair for Edit $5 - can't beat that price...
    Guest
    Richard-I just got a visual of you buying the knee highs and the gal at the check out counter giving you a double take! To each his own, huh
    Jul 2007
    Suwanee, GA
    528
    I gave up on them. More trouble than they are worth IMHO. Skimmer basket takes care of the leaves and big stuff, filter does the rest.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    So, since I can only repeat myself so many times to keep the saw dust AWAY from the pool during our deck re-do without risking 'accidental bonking in the face with a board full of old rusty nails'...as a precaution I outta just put some old pantyhose over the skimmer basket just in case?
    Cuz the Lord above should know by now I don't plan using them for their intended purpose if I can help it...
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    22,550
    Quote Originally Posted by poolgirl22
    What? There's another use for them besides skimmer basket socks, CYA delivery, sevin dust dispensing and aquarium algae scrubber?? I had no idea!
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Aug 2009
    North Central Texas
    1,358
    There's so much extremely fine stuff that makes it to my filter via the main drain the skimmer sock probably only makes a tiny dent in the very fine stuff that goes to filter (I change them out at least twice a day even if not full of larger stuff because they get clogged with fine stuff.) but they certainly help to cut down on having to clean out the pump basket, which otherwise would need cleaning daily to remove plant debris. And that's using a Pool Skim to catch most of the floating debris before it even reaches the skimmer. Pool Skim does catch loads of doggie hair and some dust too.
    Skimmer sock rules.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Aquarium Algae scrubber??? SUUUUUUHHHHWEEETT!!!!
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    Skimmer Socks Rule...for sure...
    My quest for limited sawdust is at an end. There's just no keeping it out. So skimmer sock rotation is commencing....
    I'm so thankful for TFP...
    Jul 2009
    Eastern NC
    26
    I'm a little worried about sawdust, too, as we're hoping to build a deck this month. We've considered putting a cover on, or using the solar blanket ... or maybe just leaving it uncovered & continuing to use the skimmer socks is the answer ...
    Yep, lots of yellowish sandy/spongy stuff here too when I first put the sock on (and was shocking). I still get a little of that, and a lot of dirt and **** when I vacuum (have to clean it more than once per vacuum session).
    I just turn the skimmer upside down, let the sock hang out, and alternate using an old plastic food container to scoop water from the pool and splash on the sock, and using my finger to brush the stuff into little rolls on the sock, then repeat the splashing (on my hand, first).
    13,500 gallon, 24' round vinyl AG pool, fully encircled by deck. Hayward pump, DE filter, and chlorinator (use is being discontinued), one skimmer, one main drain. Polaris 65.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    I found if you take the nylons and get big ones, pull them over the skimmer like you would normally,then push them inside out towards the basket the gunk goes into the parts left over and fills up quite a bit before I have to change it. Its good for swampy messes as well as you kill and brush the algae that is dead floats up and ends up in my sock not in my cart which I have to keep cleaning.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
