Thread: Installing an auto refill.
    chris4150's Avatar
    Apr 2009
    Cypress, TX (suburb of Houston)
    180
    Hello all,
    Was wondering if adding an auto refill was possible post pool build and if so, what would be involved. Currently I manually add water, so to speak, when my water level drops, however, I dont want to worry about my levels when Im out of town or on vacation. Also, is it possible to add an overflow run out post pool build.
    Chris
    13,500 gallon free form Pebble Tec pool- 2 skimmers
    Pentair Intelli-Flow filter pump, Pentair Intelli-Super Flo booster pump, waterfall pump, Del Ozone Eclipse 1 generator, Pentair Clean & Clear Plus Cartridge filtration, Nature 2 XG Clear Vision, In-line Chlorinator, Polaris 280, Raypack heater, and Color Logic LED lights.
    Proud user of BBB, pool school, pool calculator, TF-100, and the advice of the friendly people here!
    Feb 2008
    Denton, TX
    5,061
    Re: Installing an auto refill.
    Hey Chris,
    Here's an auto fill/leveler...
    http://www.poolandspawarehouse.com/prod ... d=PARM2000
    As for the overflow drain, I am not totally sure on that.
    They now have a wireless sensor that fits in your skimmer, that communicates to a valve at the fill line (for fill). see this: western-pool-and-spa-show-t18763.html
    - Jeff
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    To plumb a traditional autofill after the pool is built usually means cutting into the pool deck, which can get expensive. Sometimes you get lucky and can find a pipe at the right depth outside the deck area, but that isn't something you can count on.
    An autofill system requires a chamber connected to the pool by a pipe that runs below the pool water level the entire way. It must also be plumbed to the water supply. If you also want an overflow, it also needs to be plumbed to an overflow location.
    This complication is why the wireless sensors are popular. However, wireless systems aren't as reliable as hard plumbed systems and don't normally include an overflow capability.
    chris4150's Avatar
    Apr 2009
    180
    I appreciate the replys. The wireless sounds inviting, Ill have to read more about them. The over flow was more a priority for me than the the auto fill because here in Houston we get some pretty good down pours and Im having to drain the pool at the equipment via gate valve and hose. It would be nice to have the overflow drain out on its own. I know my skimmers have a knock out for an over flow pipe to be run from the pool to another location, unfortunately, this was something that needed to be addressed during my pool build.
    Chris
