Thread: Chlorine neutralizer in pH testing
    Sep 2009
    Madison, AL (north AL)
    Why did my previous test kit (phenol red pH test, that is) require drops of chlorine neutralizer but my new TF-100 test kit does not? Technically, I guess the pH testing is done from the little blue box inside the TF-100 kit.
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    Re: Chlorine neutralizer in pH testing
    The PH test in the TF-100 includes the neutralizer in the same bottle with they dye. Not only is that less work for you, but they use a better neutralizer than the others kits use.
