Thread: Chlorine Loss
    Mar 2010
    Spring, TX
    1,082
    Chlorine Loss
    Not sure if there is an answer, but if there is I am sure you guys know. Is there anyway to determine what a normal loss of chlorine is per day?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Re: Chlorine Loss
    It varies quite a bit from pool to pool and depends on your CYA level, the weather, and how much the pool is shaded from the sun, etc. A typical FC loss is around 2 ppm/day, but the range is more like 0.5 to 4 ppm.
    Mar 2010
    Spring, TX
    1,082
    Re: Chlorine Loss
    Wow that is a lot. So even with adding bleach every day you could go through a lot of bleach.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Chlorine Loss
    Well, yes, but if it concerns you then there are a few things you can do to reduce it: tweak your CYA up a little bit (in Texas, 50 or even 60 is pretty common), use a cover (reduces evaporation loss as well as a bit of FC loss).
    If you think your chlorine loss is on the high side, then an Overnight FC Loss Test will tell you whether it's due to organics.
    --paulr
    BBB "Intermediate Swimmer"
    22,550
    Re: Chlorine Loss
    As Jason said it varies a lot from pool to pool but you can get a pretty good idea of your pools normal usage. You can use the pool calculator to help.
    Here's how I did it. I tested the FC every evening and used pool calc to figure how much bleach to add. I then took that number and entered it in the "Effects of adding chemicals" section of PC to get how many ppm that much bleach would raise the FC and I charted that for a few weeks to get my normal usage. I also used that as I adjusted the CYA to tell how much it changed the usage. I use about 1½ quarts of 6% bleach per day. Which is about 2ppm per day.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Chlorine Loss
    I lose very little when the pool is not in use and the solar cover is on, prob .5 or so. When the cover is off and we are swimming on a hot sunny day it's closer to 2.
