Thread: New liner and new fill
    Mar 2008
    Garden State
    80
    I just had a new liner put in on Friday which means a whole new fill. We had 29,000 gallons trucked in and topped the rest off via garden hose from our well.
    Testing today showed essentially no FC, pH of 7.5 and no CYA (may not have let the sample reach room temperature fully though). All I have done so far is to add I 3lbs of CYA to the skimmers in socks (all I had on hand).
    My plan was as follows:
    - increase pH using soda ash (2 lbs or so) to account for pH drop due to adding CYA
    - add 6 96oz bottles of bleach to increase FC to about 8
    - re-test CYA at the end of the week to see where I am now and add more accordingly
    Is there an advantage / disadvantage to using dichlor to bring up the FC and CYA at the same time? Is it better to stick with stabilizer (any reason to use liquid as opposed to powder) and bleach?
    Thank you in advance.
    Pool Details:
    - inground vinyl liner, approx 35,000 gal; Hayward DE-6000; Pentair VS3050
    - 600sq ft Heliocol; Blue Diamond; 8 Gal Liquidator
    - TF-100
    Dec 2009
    Central Massachusetts
    2,690
    Re: New liner and new fill
    Dont add anything yet for the pH, it's fine as it is. If the CYA addition drops the pH a bit, it will be ok. Adjust it after the fact if needed. 2 pounds of soda ash will increase the pH too much. Whats the TA?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mar 2008
    Garden State
    80
    I believe the TA was 30 so it will need to be raised.
    Pool Details:
    - TF-100
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    There is an advantage with Dichlor if you already have some on hand and want to use it up - it raises the CYA very quickly. Predissolve it in a bucket of pool water and pour it in front of a return.
    If you don't have it on hand already separate CYA and bleach is cheaper.
    I would use Baking Soda to raise your TA to 80 -90 - your PH is fine where it is, you may see the PH slightly affected by the Baking Soda addition.
