Results 1 to 8 of 8
Thread: Lowering TA
    Apr 2010
    Fairfield, New Jersey
    22
    Lowering TA
    OK!!
    Here is what I have now
    FC 4
    TC 4
    PH 7.3
    TA 150
    CYA 50
    I put in 4lbs of stabilizer and 28 oz of muriatic acid. I also made a cool gismo with my air compressor. I drilled a zillion little holes in a 24ft piece of tubing laid it in the pool hooked it up to the compressor and wala "Tiny bubbles in my pool makes me feel happy and its pretty cool"
    However is my TA still too high? More acid?? and what is the TA going to do for me if its lower?
    Thanks for all your help
    Ken
    13K gal, Vinyl, 24' x 52" AGP, 1 HP pump, sand filter, 75 GPM, Chlorine
    Jan 2009
    Cupertino, CA
    1,966
    Re: Lowering TA
    Your CYA is 50 and you added 4lb? Or is that what you got after you added the 4lb (I hope)?
    What's your CH? If it's low-to-normal then there's no chemistry-balance reason to lower TA; but if you find the pH rises too fast to keep under control in a reasonable way, then it's worth purposely reducing it.
    If your CH is higher, then getting TA down under 100 is probably a good goal.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2010
    22
    Re: Lowering TA
    Quote Originally Posted by PaulR
    --paulr
    Sorry about that.. these are my readings after I made the adjustments. My CH is 300
    Re: Lowering TA
    Your current TA level is alright as long as your PH doesn't ever go above 7.8. If you have problems with the PH drifting up quickly, then it is worth working on lowering TA, but otherwise you can leave it where it is.
    Apr 2010
    Southern California
    83
    Re: Lowering TA
    Do you have a photo of your home-made aerator that you could post? I'd like to see it.
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Apr 2010
    22
    Re: Lowering TA
    Quote Originally Posted by Uncle Ben
    OK
    Ill take a picture and put on pc but how do I attacth to post??? I guess its right below this where it says
    If you wish to attach one or more files enter the details below. (256K file size limit)
    Ken
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Lowering TA
    To attach a pic it's easier to use PHotobucket or a similar photo hosting site. It automatically resizes the pics for easier viewing. These sites are usually free.
    AFter you upload to their site, just copy and past the "IMG" code into your message here and the pic appears.
    Apr 2010
    Southern California
    83
    Re: Lowering TA
    I use photobucket, and once you post photos a time or two it gets easier.
