Thread: new hayward sand filters
    Mar 2010
    Western North Carolina
    77
    I've noticed from some of the pictures here, and also looked on haywards website, that their newer sand filters have a one piece body. Other than backwashing, how are these filters cleaned, or the sand replaced?
    16'x34' IG Vinyl. 1.5HP Hayward 2spd. Hayward S244T sand. Nitro wall climber.
    Mar 2009
    Huntsville, AL
    156
    Re: new hayward sand filters
    I have one that has a top mounted valve. To change the sand I believe you take the valve off the top and use a shop vac to suck the sand out.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    All of those filters, top mount multi-port or side mount multi-port, have an opening in the top of about 8" diameter. The side mounts have a separate small black lid covering this opening. You have to do everything through that hole. It can be quite a pain sometimes, but it works.
    Mar 2010
    77
    Thanks for clearing that up. I also assume that with such a design, if anything internal gets damaged, you have to replace the whole filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by ncbrit
    No, but repair is a job for someone with long skinny arms.
