Thread: SWG makes pump noiser
    Hi, I posted this on another forum but just found this one and thought that I would post here also.
    All our equipment is Jandy, when the SWG (Aquapure) turns on, the pump makes a lot more noise. For instance, when the SWG is set on 80%, it will switch on for 80% of the time and off for 20% of the time. when the light for the swg come on the pump suddenly starts making a lot more noise. I have tried turning the swg cell around thinking that I had it in backwards but this makes no difference.
    It is not just a little more noise but quite a bit more, enough to bother us when we are on the patio. It has been doing this since new, I just now figured out that the extra noise happens when the swg comes on, before I thought that I just had a noisy pump with a bad bearing or something.
    Has anyone else had this problem?
    Thanks, Tim
    Try replacing the capacitor on the motor. I just had the same thing happen to me and it worked.
    15' x 35' gunite/plaster inground pool with Coverpool automatic cover and integrated spa
