Results 1 to 7 of 7
Thread: Need help choosing new pump
    Nov 2007
    Benton, Ky,
    18
    This pool is around 20 years old and came with the house when I purchased it 3 years ago...
    I've always thought this Hayward Super Pump 1.5hp was too big for the pool but due to $$ constraints I couldn't upgrade at the time 3 years ago...
    Now, this year, the pump motor sounds like a blender chewing up ice cubes...it's still working but very loud...
    So, I'm in a $$ position to change this pump to a more efficient and properly sized pump...
    I really like the idea of a 2 speed pump...so that I can filter on low speed and then clean and vaccuum on high speed...
    I also would rather run the pump 24/7 instead of dealing with timers and such so a simple setup with an on/off switch and a high/low switch would suit me just fine...my pool is open from April to Sept...
    I don't have any water features or a spa so the basics of my setup are in my signature below..
    I'm really leaning towards the same Hayward Super Pump in a 2 speed model so that all my plumbing will match up easier...(I have disconnect unions on all my plumbing so I can take my pump indoors in the winter)...
    I really want to change the whole unit (not just the motor) because the housing, strainer basket, lid, drain plug ports are all in pretty rough shape and the entire unit would give me peace of mind....
    So, to start with, I have 2 questions...
    What size 2 speed pump would suit my setup efficiently and sufficiently..
    Which has a better strainer basket lid seal design...the Hayward Super Pump or the Super Pump II..?? (The lid seal design of the Super Pump that I have now is the only thing I do not like about this unit because the gasket seems to get bigger every time I open the lid causing the gasket to need changing way too often IMO...)
    If there is more info that I need to post, I will do my best to supply it...
    22K gal. IG rectangular, 1 skimmer 40ft from eq. pad (2" line), 1 main drain 8ft deep-10ft from eq. pad (1.5" line), 2 eyeballs diagonal from each other-10ft & 50ft from eq. pad (1.5" line), Hayward Super Pump 1.5hp, 20" sand filter, 16psi normal operating,
    22,553
    Re: Need help choosing new pump
    Definitely go with a 2-speed pump. If the new Hayward pump matches the current pump you have I'd seriously consider going with that and you wouldn't have to change the plumbing. I don't think you'd go wrong with it.
    I'm really happy with my Pentair whisperflo.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Nov 2007
    Benton, Ky,
    18
    So...my questions are...
    What size 2 speed pump for my setup...??
    Is the Hayward Super Pump II basket lid seal design better than the lid seal design of the Hayward Super Pump...??
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    South Central NJ
    3,192
    A Super II will not line up correctly.
    Most two speeds require 230V service. All Hayward Super Pump 2 Speed units do as well as Jandy's FloPro.
    A Pentair SuperFlo 3/4 HP 2 Speed is the only one I found that will take a 115V line.
    If 230V service is there, a 1 HP 2 speed is the lowest appropriate size I found that will line up. All 3 makers, Hayward, Pentair, and Jandy make a pump that will line up.
    BTW, the 20" filter is a bit small.
    Scott
    Owner of - PoolGuyNJ LLC
    I would either go with a 1HP two speed of the same brand/model you currently have, or if your electrical rates are high move up to a variable speed pump.
