Results 1 to 9 of 9
Thread: Bad Temp reading/Calibrate temperature problem
    I'm having a problem with the temperature readings on my IG spa/pool......pool equipment (Pentair Easy Touch) is reading 116 degrees while the actual temp is more like 74 degrees. I tried to recalibrate the temp under settings, but the change doesn't stick for some reason. Any ideas? Bad sensor (it's not even a year old)?
    txpoolguy
    15,000 gal
    IG plaster
    Cartridge filter
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Bad Temp reading/Calibrate temperature problem
    Did this just start to happen or did it always do this? Check the location of the temperture sensor. It should be before the heater. Otherwise it could just be a bad sensor.
    Mark
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    You have a bad temp sensor. If it is under a year, it can be replaced under warranty.
    Factory Warranty Station for:
    Guest
    Let me ask (add) this question: What if the temp sensor and the heater are only 4-6 off of each other? Which is "off"? What would you consider an acceptable +/- temp differential?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Quote Originally Posted by simicrintz
    Which is "off"?
    Every sensor that differs from an accurate thermometer.
    South Central NJ
    3,192
    I don't normally recalibrate unless there more than a 2 degree delta from an actual reading.
    Scott
    Owner of - PoolGuyNJ LLC
    Guest
    Thanks guys! Just wondering what parameters you were using for "acceptable".
    Thanks for the help (and quick response!), that's what I figured......will put the call in tomorrow to the warranty dept. and see what kind of response I get.
    txpoolguy
    15,000 gal
    IG plaster
    Cartridge filter
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If you have solar, before you call, make sure you haven't by accident wired the solar sensor to the water temp sensor bus, and vice versa.
