Thread: Pool deck / coping: cut or no cut? Need advice.
    I have an in-ground vinyl pool which was installed earlier this month. The pool decking is made of cement with a sprayed on texture which is painted (see pics). The pool installer cut "slits" in the cement around the pool, more than likely to prevent cracks from expanding & contracting cement.
    My question is: should the coping be cut too? I am finding that the coping is cracking where the slit was not extended into the cement coping (see pics). I'm trying to get an idea before I speak with my builder. It may be just something I have to live with, but if it was supposed to be done, I want it done!
    Please excuse the mud pit in the background. I can't wait until my grass grows back!
    My wife did an excellent job in picking out this liner. The colors match perfectly IMO.
    No cracking yet.
    Thank y'all for your time and assistance!
    -Dennis
    15,000 gallons in-ground kidney shaped, 15' x 30' Vinyl liner 3.5' to 6.5' deep
    1 ½ hp Pentair Challenger pump w/ Intermatic timer (220V)
    Pentair Sand Dollar Top-Mount Sand filter SD-60
    Pool construction began 3/15/10. Finished 4/03/10.
    BBB Method with Salt (No SWG, possibly next year)
    TFTestkits TF-100 XL & Lamotte Borate test strips
    Add borax to improve feel & prevent algae
    The Pool Calculator
    Feb 2008
    Denton, TX
    5,061
    Re: Pool deck / coping: cut or no cut? Need advise.
    I really don't have any advice for your situation, but your pool is beautiful!
    22,553
    Those cuts are to hopefully "guide" the cracking along the cut and looks like it's doing what it's supposed to. I'd call the PB but I'm not sure you need to do anything about what's happening. The only thing you'll accomplish by cutting the coping nose is maybe a little asthetics. then again they'll have to repaint it and that may look worse.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Re: Pool deck / coping: cut or no cut? Need advice.
    Quote Originally Posted by 257WbyMag
    Thanks! It doesn't compare to some of them I've seen on here, but my wife and I are pretty happy. We just need some grass! I'm so tired of sand and dirt!
    Those cuts are to hopefully "guide" the cracking along the cut and looks like it's doing what it's supposed to. I'd call the PB but I'm not sure you need to do anything about what's happening. The only thing you'll accomplish by cutting the coping nose is maybe a little aesthetics. then again they'll have to repaint it and that may look worse.
    Thanks for the advice!
    Does anyone have any pics of their coping nose having been cut all the way through, so I can compare and decide?
    -Dennis
    The Pool Calculator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Ours is a little different, but hope it helps!
    30,432
    ASk your PB. I suspect you might find that's aluminum coping underneath that kool deck overspray.
