Results 1 to 12 of 12
Thread: My Journey from Green to Crystal Clear
    Mar 2010
    Spring, TX
    1,082
    Hope this little post can help those that seem to want to give up. Do not give up. It is hard and at times you do want to give up but you can get there. I know mine is not near as bad as some, but it took a lot of work for me. I never had any experience with taking care of a pool until I started working on the pool. Started around beginning of November 09.
    Enjoy
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2010
    Spring, TX
    1,082
    Re: My Journey from Green to Crystal Clear
    Here are some more pics.
    Mar 2010
    Spring, TX
    1,082
    Mar 2010
    Spring, TX
    1,082
    Mar 2010
    Spring, TX
    1,082
    And Now almost 6 months later and a lot of POP and questions on the board.
    Mar 2010
    Spring, TX
    1,082
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    That's what we like to call "sparkly". Great job
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by frustratedpoolmom
    Pictures 618 and 623 I thought that was clear. But not it is as you say "sparkly".
    Thanks for the kind comments. I am hoping this can help others not give up.
    Aug 2009
    North Central Texas
    1,358
    Great Job. And really good for others to be able to see. In the winter it does take longer because of the slow down of chemical reactions due to cold water.
    Is that big angled "roof" going to be used for solar panels? I bet you had to do a lot of backwashing.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by geekgranny
    gg=alice
    The angled roof I think the one you are talking about is part of the house. I would say like 2-3 times. May had needed more, but what I did seemed to work. I did take it apart about a month ago or so and it was very dirty. So maybe should have backwashed more.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Tremendous!
    Only thing that worries me is that floater...
    Watch the CYA level or you'll end up like me, unable to use the simple color-matching test for Chlorine
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by Richard320
    Tremendous!
    That floater is just in there. The stuff inside is almost gone. I have had it in there for a while, but the pucks are almost disolved.
