Thread: 2.0 hp or 1.5 pump/ 2 speed or 1 speed
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I had a 1.5 hp pump for 9 years with a 24' above ground pool and it worked fine. I originally had a 1 speed/ then later a 2 speed. The two speed was nice- but I don't think I ever used the low speed; and I can't remember why-I think I thought it filtered better at high speed. Now I read on the internet that the pool filters better at LOW speed- is that true???
    I moved and am purchasing new equipment and everything I read just makes my mind numb.
    I want to be energy efficient; but reasonable in up front costs. The pool store says their two speed pumps (2 hp with 12amp high and 4amp low speed)- can cost 1/3 the cost to run if the low speed is chosen. I just don't think the math is that simple on that; that doesn't sound right.
    I'm so confused in calculations- I calculated at $.08 a kilowatt; it would cost at least $65 a month to run a 1.5 hp pool pump all month long..... if that's the case, I'm thinking about just scrapping the pool and swimming at the YMCA.
    Seriously, can anyone comment any on the best economical choice up front for pool and filter?
    Intex 22' x 52" - Intex Krystal Clear Sand Filter Pump - flow rate: 2,150 gal per hour
    TFTest Kits TF-100
    Waiting to stop relocating until I build my dream pool!
    Re: 2.0 hp or 1.5 pump/ 2 speed or 1 speed
    Welcome to TFP!
    A two speed pump can indeed cost 1/3 as much on low speed, even though you have to run it for twice as long. It isn't always that much less money, the actual savings vary somewhat, but there is always a substantial savings. The larger the pump, the more total electricity it uses, Low speed is just like having a substantially smaller pump when it is running on low speed, and you still have high speed available if you happen to need to for something.
    For your pool, with relatively low electric rates, a two speed 1 HP pump would probably be the best choice.
    cfclay's Avatar
    Apr 2010
    Little Rock, AR
    204
    I have found consistent mentions that most pool pumps sold have to much HP; like you are saying 1 is probably adequate (and more energy efficient)
    TFTest Kits TF-100
    How would running it at the lower speed effect the Polaris? I have a separate booster pump for my Polaris. I don't know how the pool is actually plumped since the Polaris has a light flow of water coming out of it even when it is off and the main pump is on. This tells me of course that the plumping for the two is not separate. It's an Anthony and Sylvan Pool.
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    As long as you have a separate booster pump and the main pump is on any time the booster pump is on, you will be fine even at low speed on the main pump.
