Thread: Another First Time Opening Question
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hi All,
    Last year we had our pool installed and we used the BBB method the entire year
    Current our pool is scheduled to be opened on 4/30. At that time, A pool service company will be removing the cover an reinstalling the filter and pump.
    Today I pulled up a corner of the cover so I could get a look at (and test the water.)
    The good news is that I can clearly see to the botom of the deep end. It is hard to tell the color of the water because most of the pool was still covered... bu it looked pretty clear.
    Here are my first test results:
    TC: 0
    CC: 0????
    PH: 7.2
    CYA: 0???
    Water temp: mid to low 50's
    My question is: I have a small submersible pump, should I start adjusting these numbers now, or wait until the opening on the 30th?
    Thanks again,
    -Ken-
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Re: Another First Time Opening Question
    Wait till the pool is open and the pump has been running for a couple of hours, then test all your levels again. Testing while the pool is closed and the pump hasn't been running can give very misleading results.
