Results 1 to 9 of 9
Thread: Which is a better deal-Liquid Chlorine or Bleach
    Mar 2010
    Spring, TX
    1,082
    Ok I am trying to figure it out but just cant.
    Liquid Chlorine-4 Pack (128 oz)=16.46=.03 per oz (approx)
    http://www.homedepot.com/webapp/wcs/sto ... =100186484
    Bleach-1 (182 oz)=2.54X4=10.16=.01 per oz (approx)
    So from my understanding you use about about 40 less of the 10 percent.
    So I took the Liquid Chlorine and it is a total of 512 and the bleach is 728.
    Add the extra 40% to the liquid chlorine (204.8) + 512=716.8=.02 per oz
    Is my math correct or am I doing something wrong?
    Thanks. To me it appears bleach is still the better deal.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Which is a better deal-Liquid Chlorine or Bleach
    Insufficient data.
    Without knowing the concentration of each, you can't really compare. Is the bleach 6%, 3%, or even lower? My wife bought some dirt cheap store brand stuff for laundry, it's 2.75%!
    The pool chlorine could be 10% or 12.5%
    Multiply ounces by percentage to get actual chlorine ounces. Then divide dollars by ounces to get comparison values.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The higher the concentration the more rapidly it degrades.
    there was another thread from a year or two ago where price was discussed in detail, I'll see if I can find it.
    Pool Store liquid chlorine at higher concentrations vary greatly regionally. I can get 4 bottles of 12.5% for $12.
    11,969
    Here's that thread
    http://www.troublefreepool.com/walma...40.html#p98641
    At some time during the last year Walmart's jugs became 182 oz instead of 174 oz so the math needs to be reworked.
    Toms River, NJ
    151
    I find that the easiest calculation to make is the cost of raising your FC some set amount for each media.
    For instance, in my pool, comparing 6% bleach to 12% liquid to 73% powdered Cal-Hypo:
    1 182 Ounce Jug of 6% bleach at Walmart: $2.54
    1 5-gallon carboy of 12% liquid chlorine (price varies for me, but average): $20
    1 1lb bag of Cal-Hypo: $3.50
    Using the pool calculator, and all other variables remaining the same, I need the following to raise my FC by 1 ppm:
    94 oz (by volume) of bleach
    or
    47 oz (by volume) of 12% liquid chlorine
    or
    8.3 oz (by weight) of 73% cal-hypo
    Remember to keep those units uniform - bleach is sold by volume and Cal-Hypo is sold by weight!
    Now the calculation is fairly simple to find out the percentanges:
    ( Required Measurement / Total Purchased Measurement ) * unit price = Price per PPM.
    so for each:
    bleach: (94 oz / 182 oz) * $2.54 = ~$1.31
    12% liquid: (47 oz / 640 oz) * $20.00 = ~$1.46
    cal-hypo: (8.3 oz / 16 oz) * $3.50 = ~$1.82
    So for me, bleach is cheaper than either liquid chlorine or Calcium Hypochlorite unless I also need to raise my calcium hardness, in which case another cost factor is introduced.
    Also, you can weight (but probably not quantify reliably) the fact that when you buy 12% at the store, it may have degraded and may be only 10% or even less. For me personally, I'd need to see the price of the carboy drop to about $17 before it's worth it for me, and only then if I need it that day, because it will certainly degrade if I buy it just to keep it on hand.
    Does this help you?
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Mar 2010
    Spring, TX
    1,082
    Looks like I will be sticking with bleach. It is readily available by my house.
    11,969
    Quote Originally Posted by baudilus
    Does this help you?
    Helps me... that's a much easier way of calculating it.
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    I get a 20% off on my liquid chlorine each spring from my local PB. I buy enough to shock in the spring and then enough to last about another month without losing out on the % of concentration in the bleach.
    Plus they usually deliver it for me when they are passing through town as the main business is 100 miles away so not only do I get a good deal, but delivered right to my door is pretty hard to beat. Gives me a chance to visit with them as well and ask them a few questions on various topics. All mechanical questions. I dont need any advice any longer on the chems and that is all thanks to BBB and this website!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    Wow, $20 for 5 gls of 12%. My pool store sells (2.5 gals @ $4.50) 5 gals of 10% for $9 also once in a while it is buy 2 get 1 free so i usually pay $9 for 7.5 gals of 10%, I'm not sure if it is 10% or 12% but using the lower concetrate is still cheaper.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
