Results 1 to 13 of 13
Thread: Tanning Oil and your pool
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hello All Masters, whats the effect of tanning oil in your pool
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
    Feb 2008
    Denton, TX
    5,061
    Re: Tanning Oil and your pool
    With heavy pool use, we will see a slight sheen on the surface of the pool water. It's usually gone in a hour or two as my pool has strong skimmer action.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Thanks for the quick reply. I was told it could damage the filter, pump.... Which I thought was crazy but wanted to ask the experts here to see what you all thought. Also, my cousin said it creates lots of algea... Any thoughts on these assumptions?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Just that, assumptions.
    Feb 2008
    Denton, TX
    5,061
    Tanning oils and lotions can dirty the filter, but so do other things and filters do require ongoing maintenance. The sole reason that folks get algae is because their pools have inadequate sanitizer levels.
    11,969
    Quote Originally Posted by 257WbyMag
    Well that was a much more useful response than mine.
    I hate sun block / tanning oil ect. It just washes of in my pool and leaves a bath tub ring around my title. I am sure it is coating the filter as well. I try to tell my wife and here friends that the stuff just washes off, but they are sure the will get skin cancer without it. They put it on themselfs, the kids, the dog, the neighbors kids and I have to deal with bathtub ring around my pool. Its not as if I could just get some Ajax soap or dish soap and remove it from the tile, I wouldn't want that stuff in my pool either. I hate tanning oil and sun block.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Thanks for the replies and both were just fine and along the lines I was already thinking. Why else do we backwash and sanitize....
    Have a great weekend We're gonna try to do some swimming if the storms hold out
    Small amounts of tanning oil, sunblock, etc are hardly noticeable and get broken down by chlorine reasonably quickly.
    Medium amounts of oil can be handled by using a Skum Bug or Scumball in the skimmer. They soak up the oil, and need to be cleaned or replaced occasionally.
    Large amounts of oil can cause problems such as what atomicdog describes. You can help control major amounts of oil using an enzyme product designed to speed up the breakdown of oils, such as Pool Perfect or ProTeam Power Enzyme.
    Really extreme amounts of oil can potentially clog the filter, though this is quite rare.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I suppose in extreme cases, it can end up like the indoor pool where I'm staying. There was a huge pile of scum... looked like shaving cream or cake frosting about 6" high in one corner of the hot tub section. And a rainbow sheen on the pool. Why folks wear sunblock in an indoor pool is beyond me. Maybe it was just moisturizing lotion.
    Apr 2010
    Austin, TX
    49
    Quote Originally Posted by atomicdog
    Just a word of caution/surprise from a newbie looking at getting a pool, but since it is a fact that sun exposure over time will lead to both benign and malignant types of skin cancer, isn't it worth the protection for skin cancer if you need to clean up the stuff?
    10K IG, Gunite with Wet Edge "Midnight Ocean" pebble surface, with spa, tanning shelf, and fountain. Pentair Intellibrite LED pool and spa lights. Rola-Chem chlorine pump (and tank), Pentair DE "Quad 80" cartridge filter, 400K BTU gas heater, VF Whisperflo, and Legend Pressure Side Cleaner with Pentair booster pump. Using TFTestKit.
    kellyj, welcome to TFP!
    Sunblock, tanning oil, etc isn't a problem for most pools. It all depends on the brands used and how many people are swimming. Most residential pool owners either won't notice any oil, or can keep everything under control easily with a scum bug, even if everyone in the family uses sunblock.
    Jun 2007
    New Jersey
    653
    I do get peeved at teenagers who goop themselves up and then immediately jump in the pool, leaving a spreading oil slick on my pristine waters. My rule is wait a half-hour after gooping or take a shower before jumping in. I encourage gooping AFTER dipping, not the reverse.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
