Thread: Bought my new pump! Need hoses.
    Nov 2009
    Cleona, PA
    236
    I bought a Hayward Power-Flo LX SP1580, 1HP pump. The sand filter is on the pad, but nothing is connected to the pool.
    The skimmer suction line is PVC from the skimmer at the far end of the pool down to the cement pad where the pump and filter go. The cement pad is right next to the return port on the pool itself.
    I can't find the hoses that the previous owners used, so I'll have to get new ones.
    Do I use hose? or PVC pipes?
    I have some pics:
    The suction is a 2" pipe
    The return is 1 1/2"
    The suction from the skimmer opens to a bigger joint
    The filter
    The whole setup (without the pump)
    13,500 Wilkes Vinyl AG (15'x30' rectangular)
    Hayward S-160T High Rate Sand Filter
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: Bought my new pump! Need hoses.
    Looks like barbed fittings, use flex hose and hose clamps.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    22,542
    If you do go with flex hose, double clamp all the fittings.
    Also, that pipe is really 1-1/2". 1-1/2" pipe is 1.9" outside diameter and 1.59" inside diameter. I'f you'll look on the side of some of those fittings the size will be molded on there.
    Nov 2009
    Cleona, PA
    236
    Thanks. How about the fitting on the end of the pipe from the skimmer? Can you tell what that is?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    That's half of a union type valve. The pipe itself is 1.5" Schedule 40 PVC. That's what I'd recommend for the whole works. You can get parts and fittings at most any Home Depot, Lowe's etc., even on Sunday to fix problems. And use plenty of unions so you can take it apart.
    Looks like maybe they have it set up so you can take a plug out of the skimmer pipe to drain the pool down for winter and to keep the water level down while it's closed.
    Nov 2009
    Cleona, PA
    236
    Thanks for the input.
