Thread: Sand filter laterals
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I am changing the sand in my Hayward filter, as I don't know when the previous owner did it, and I'm on my 3rd year of ownership. The old sand doesn't look too bad compared to the new stuff, just a little yellow and clumpy at the bottom.
    Anyhow, I took the laterals out to clean them, and facilitate removal of all the sand. I noticed that the pipe going from the multi-port, down the the laterals had a crack in the bottom. Now, where the crack is, is where the water would distribute to the laterals, below that is only a hollow space, then back to the sand filter via a cover of the hollow area. (Am I making sense?)
    In my opinion, I don't need to worry about it, I may just put a little silicone over the crack and reinstall it. The hollow area had sand in it, I'm assuming for weight to hold the assembly down while refilling the sand.
    Am I on the right track?
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Sand filter laterals
    its hard to understand where the crack is, but no crack is good crack.. well the stuff i used to get from this guy.. ehh never mind. :P
    Theres a bit of pressure in those filters, and you may have dirty water getting back into the pool, or even sand. A new lateral assembly isnt too expensive. I would just buy a new one. If you put it all back together and have a problem a week form now.. your going to have to take it all apart again.
    Get yourself some pool puddy, repair your current one and keep it as a back up
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    South Central NJ
    3,192
    Sounds like a Hayward filter. That crack will grow. It will let pool sand into the pool from the filter. Replace it. It comes complete with laterals.
    Scott
    Owner of - PoolGuyNJ LLC
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thats what I was afraid of Scott, and yes, its a Hayward. My thought was, if it ever busted through, it would just push the water right through the bottom and bypass the laterals.
    Thanks!
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Just called the local pool place, 80-95 bucks, depending on model.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    $108.00 later, there is a new lateral assembly in my garage waiting to be installed. I really like that they made the laterals fold up now for installation/removal. The old one was a bit of a pain to screw each one off through the small opening.
