Results 1 to 8 of 8
Thread: kenerator 3
    Apr 2010
    Fairfield, New Jersey
    22
    kenerator 3
    I also have a Hayward CL 100 Chlorine feeder which I turned Off after I found my chlorine high.
    Also am I using this forums correctly? Do I create new topics when I am talking back and forth?
    13K gal, Vinyl, 24' x 52" AGP, 1 HP pump, sand filter, 75 GPM, Chlorine
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: kenerator 3
    If you want to answer a post, then you can either hit the "quote" button in the upper right corner of the post you wish to reply to, or you can scroll down to the bottom of the page and start typing in the box titled "quick reply". If you just start a new topic no one will know what you are talking about! Welcome to TFP, by the way!
    Love TFP? Become a
    TFP Supporter!
    Apr 2010
    22
    Re: kenerator 3
    Ok I think I got it thank you. Now how do you think can I fix these readings:
    CL 5+ (I turned off chlorine feeder)
    PH 7.7
    FC 7.5
    CC 0
    TC 7.5
    TA 400+ did not turn red -turned blue and I gave up at 41 drops (I did this test twice) same thing happened
    CH 350
    CYA 20
    24ft round 52" Vinal Above ground pool
    Hayward sand filter 1hp pump Raypak gas heater Hayward CL100 Chlorine feeder
    Re: kenerator 3
    Your CYA is a little low. I would raise it to between 40 and 50.
    Your TA is either very very high or there is something wrong with your TA test. You should try it again, wiping the tip of the bottle with a damp cloth or tissue before you start and after every four or five drops. Sometimes the TA test goes from blue to yellow instead of from green to red.
    Apr 2010
    22
    Re: kenerator 3
    Ok ill try the test again what do you suggest I raise the CYA with ?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: kenerator 3
    You raise/increase CYA with Cyanuric Acid, sometimes labeled as conditioner or stabilizer.
    Make sure that you are buying 100% Cyanuric Acid (or close to 100%).
    You can purchase at Lowes, HD, pool stores, etc.
    I think my Lowes had it for about $13 for 3lbs, but they were out. So, I purchased from my pool store @ $27 for 6lbs.
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: kenerator 3
    What's the difference between "CL 5+" and "FC 7.5"? Is the "CL" some sort of dial setting on the chlorine feeder while the FC is the Free Chlorine reading from a test kit?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: kenerator 3
    I took it as a reading of the OTO yellow test...?
