Results 1 to 9 of 9
Thread: Question regarding TF-100 reagent R-007
    Sep 2009
    Madison, AL (north AL)
    77
    Is it just me, or do the drops come out of this bottle like machine gun bullets? I just got my first TF-100 test kit today and was excited to use it. Most everything went well, but when doing the TA test, I discovered that the drops from the R-007 bottle are much smaller than the other bottles and they seem to fly out. If I'm SUPER careful, I think I can accurately dispense 2 drops, but it's not easy.
    Does this sound right, or am I messing something up? I had no problems with any of the other reagent bottles in the kit.
    Phillip
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    Re: Question regarding TF-100 reagent R-007
    That sounds like a static electricity problem. Try wiping the tip of the bottle with a damp cloth or tissue before you start and after every four or five drops.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    It happens to me, too.
    I just assumed the reagent was very low viscosity. I squeeze out ome air while it's upright then relax it as it is upended and let the vacuum hold it in.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    I had a similar problem with my titrating drops for my TA test...They were coming out two at a time...I wiped the bottle and it worked fine...I knew about the static electricity and completely forgot about it. I couldn't squeeze the bottle lightly enough.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Feb 2009
    NW Chicago Suburb, IL
    75
    Same thing happened to me with the 008 reagent. I wrote to the test kit email and they suggested that I swap out the dropper top with another one. What I ended up doing was getting the top off of the bottle and blowing and rinsing it out. That fixed the problem. I get normal sized drops now.
    You can get the top off by carefully pushing on the dropper top sideways.
    15,000 Gallon IG 15x30 fiberglass
    CoverStar auto safety cover
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    30,431
    The dropper tips used in the TF-100 and the K-2006 have the same size orifice. The TF-100 dropper tips all come from the same batch (as do probably the K-2006) regardless whether the reagent is R-0007, R-0012, R-0008, etc.
    The only repeating issue I am aware of with the drops not forming normally is when using the R-0009. That is a static electricity issue that seems unique to that particular reagent.
    Certainly, any dropper tip could be clogged or defective but that incidence has been so small (almost non-existant) that it is hardly worth mentioning.
    Feb 2008
    Northwest Indiana
    902
    The R 0009 is the TA titrating drops...right...That is the only one I have had trouble with...When they come out fast like that the drops seem smaller and come out two at time...is that the Static problem?
    Beave
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by cubbybeave08
    Sounds like it, yep. Wipe the tip with a damp cloth every few drops, see if that makes the problem go away.
    --paulr
    BBB "Intermediate Swimmer"
    Sep 2009
    77
    Must have been static. I used the damp cloth, and the drops were then just like the other bottles. Thanks!
