Results 1 to 14 of 14
Thread: Jack's Magic vs. HTH Metal Control
    Dec 2009
    Central Massachusetts
    2,690
    Anybody have experience with the HTH metal control? I believe it is phosponic acid based rather than EDTA, similar to Jack's. I have used Jacks with good luck. Clears the iron I have in my pool right up when I add fill water. But...it's ~$25 a quart. I see amazon has HTH for 10 bucks a quart if you buy a 6 pack. Sounds too good to be true. I was going to try it out, but if anybody has a negative, or positive comment, I'd like to hear them.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    Re: Jack's Magic vs. HTH Metal Control
    Dang, that's a great price. I'm interested in the answer to this too.
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    Aug 2009
    North Central Texas
    1,358
    I used that all winter after doing an AA treatment in fall using another sequestrate during the process. My stains are iron from our sediment dragged in by dogs and blown in. It has continued to lift the scale for months and has kept stains at bay. I didn't measure how much I used and probably used more than the minimal dose.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    South Central NJ
    3,192
    I am always leery of anything with the HTH brand. There's a reason it's so much less and I guarantee it isn't because they are what's best for the consumer. Sticking with the Jack's and avoid all things HTH is my own personal rule.
    Scott
    Owner of - PoolGuyNJ LLC
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    All things? I recommend the HTH stabilizer all the time....their 6-way test kit is fine...
    Tim23's Avatar
    Feb 2010
    Livingston, Louisiana
    61
    Quote Originally Posted by frustratedpoolmom
    Not trying to get off the original post, but just a quick question. Where can you get refills for the 6-way test kit?
    Tim
    Oh and our local Walmart had the HTH metal out for $11.
    Delair 27', 52" round AGP. 19,300gal
    Waterway 22"/1.5hp pump, 2 speed/sand filter, BBB
    My BBB motto.."LESS IS MORE WITHOUT ALL THE CHORES, SO FOLLOW TFP AND IN THE END, THE POOL OWNER SCORES"!
    11,969
    You can't that I'm aware of, I tried three years ago, but then ended up getting a TF100. Honestly if you are going to spend money on more testing reagents, just get one of the recommended kits from Taylor or TFtestkits. You won't regret it.
    Dec 2009
    2,690
    I did some more research on it last night after i posted and it is phosphonic acid based, like jack's. I'm not a brand fanatic. If it works, why pay for a brand name.
    Phosphonic acid based sequestrants are better as a class compared to other kinds of sequestrants, but they are not all the same as each other. By all means, try out some less expensive brands. Just don't automatically assume they will be just as good as the expensive brands. A given brand might be just as good, or it might not, or it might vary over time. Most of the less expensive brands purchase chemicals in bulk from other companies and the bottle them. Depending on pricing they may change suppliers for different production runs. The best thing to do is to try it out and see how it works for you.
    The top brands we recommend are recommended because they have worked consistently for many different people over a long period of time. Less expensive brands come and go and change over time. There is almost invariably a less expensive brand that works just as well at some specific point in time. But there hasn't yet been an inexpensive choice that has proven reliable over longer periods of time.
    Dec 2009
    2,690
    Gee Jason, like to cover your bases much
    My wife picked some up at Walmart this morning. I'm going to try it and see how it works.
    Feb 2010
    Houston, TX
    271
    Hope it works better for you than it did for me...a few years back when we first put up our Intex pool (15x48) I tried it. I first used to rec. dosage, did nothing. I gradually did higher and higher doses until I was using a couple bottles per dose, and it never worked. The only solution for me was to shock up to around 20 ppm, and once I had ~5000 gallons of tea I had to floc and vac to waste. Then I refilled with water softener water. From then on when draining and refilling the pool each season I always used softened water. It may have taken a couple days, but at least I didn't have to deal with the iron.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Dec 2009
    2,690
    Thought I'd bump this and let you al know how it worked. I added 1 quart of HTH Metal Control to 14,000 gallons. I added it around 3 pm and ran the pump overnight. The next morning it was clear and blue again. I will say that in the past when I've used Jack's purple, it clear a bit faster, but I am happy with the results. For 10 bucks a quart, i'll keep using it.
    Feb 2010
    Houston, TX
    271
    Glad to hear it worked for you. I probably should have mentioned that sometimes our fill water is extremely high in iron content (+5ppm, I don't remember what it was the last time it was tested). So, our situation here is a little different than what most people here probably have.
    John
    Dec 2009
    2,690
    Wow. 5 ppm is pretty high. Mine only tops out around 2, and thats in August when they turn on the iron heavy well. Right now it's 0.5 ppm, so its much more manageable.
