Results 1 to 10 of 10
Thread: Stabilizer - Is this part of the BBB method?
    Jerry's Avatar
    Aug 2009
    New Orleans
    48
    A freind in the pool resurfacing biz says that I need to add Stablizer after shocking the pool.
    What say y'all?
    10,000 Gal. Inground Plaster Lap Pool
    Sand Filter
    New Orleans, LA
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Stabilizer - Is this part of the BBB method?
    Hi Jerry, have you read Pool School?
    CYA or "Stabilizer" is essential to proper water chemistry. It should always be present, including when you are shocking - otherwise the FC is destroyed by sunlight.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Jerry
    What say y'all?
    Well, if we had a full set of test results, and a description of how your water looks - or a pic, then we could advise better!
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Well of course it is We just don't like to put it as BBBS
    You need to have a certain level in the pool (10 - 80 ppm, dependent upon your particular situation/ pool) and maintain ~ that level.
    You'll only loose the CYA by removing water from the pool (*).
    As for needing to add CYA whenever the pool is shocked - NOPE! He probably is of the mind that a weekly shock dose of cl is required, which is also wrong
    If anyone is interested in why I say what I do - give Pool School a read and get a basic understanding of why we say what we say
    Luv& Luk
    -Ted
    Apr 2010
    Southern California
    83
    I was just about to post a similar question, so I'm glad I saw this thread.
    My question in addition to the OP's question is: since you have to wait a week for the CYA to dissolve before testing for it in your pool, how to you make sure you don't add too much of it since it takes so long to register on a test?
    I want to make sure I don't add too much at once since I very much want to avoid having to do a partial drain later to bring down CYA.
    12,000 gallon IG (newly re-plastered) pool, Pentair 3/4hp pump, DE filter, TF-100 test kit
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by waste
    Hmmm...I don't know. BBBS kinda has a ring to it.
    22,549
    That's what Pool Calculator is for. Put in your starting number and your target number and it'll tell you how much you need to add. We recommend adding a bit less than recommended, wait a week, test again and add the rest if needed. Because, like you said, it's better to be a bit short than to have to drain water.
    Apr 2010
    Southern California
    83
    Awesome, thanks. I keep forgetting about the calculator...
    Also, I've seen different recommendations for adding the stabilizer:
    a) to put it in a sock in the skimmer
    b) to dissolve it in a bucket then slowly pour it into the pool in front of the skimmer
    c) other suggestion??
    Which way is the "best"?
    11,969
    Sock method, in front of a return or in the skimmer.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I prefer nylon knee highs myself, and even use one for CYA in the skimmer. Just make sure you don't block the skimmer when you put it in there.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
