Results 1 to 8 of 8
Thread: will mulch around bottom of agp cause sides to rust?
    May 2009
    Jasper, TN
    249
    I know a lot of people bury AGP and I've always wondered if that shortens the life of the walls by causing rust.
    My AGP is not buried. I'm trying to find an ECONOMICAL way to landscape around it. I can't afford a lot right now but would like some other than the dirt ring around the pool. The ground is slightly uneven around it with one side about an inch higher (the level of the ground).
    I'm considering mulch, but concerned it may hold too much moisture around the bottom couple of inches of the pool wall.
    I've also thought about gravel but don't have a cheap source around here and don't want white gravel that will discolor and show up stray blades of grass that get blown on it after mowing.
    Any suggestions for the most economical way to 'pretty up' around the pool? I have a deck about 8 feet wide on one side but other than that, there's nothing else around the pool (except for the pump/filter).
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Aug 2009
    SW Wisconsin
    518
    Re: will mulch around bottom of agp cause sides to rust?
    I have been toying with the idea of doing decorative mulch as well, as that's what we have around the rest of our house...but it does retain moisture...I may landscape around the pool with river rock, or maybe pea gravel instead. We'll see...whatever is cheaper at the time!! ) If you want, you could always lay down some landscape plastic up the side of the pool a bit and into your landscaping area BEFORE you put down mulch and that will help keep it away from you pool wall.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Casey's Avatar
    SW PA
    10,423
    I used river rock from the river. I hand picked every single one of them and packed them up myself to cut the cost the labor was hideous though.
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by Casey
    Looks good. But wow... yeah that would be a lot of work. I got a bad back too so it would take quite awhile but yeah I think I could get some like that for free
    Did you put plastic under? Do you have a problem with weeds growing through them?
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Have you looked into the fake mulch? Lasts much longer than regular, and looks nice too.
    Not too expensive, It's about 20 dollars a bag. the bags are bout the same size as regular mulch.
    The only catch is that when it its past its prime you have to remove it rather than just addingf to it like regular decomposed mulch. I believe it has a 7 year lifespan.
    You could leave it, It just fades color.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Casey's Avatar
    SW PA
    10,423
    Quote Originally Posted by rastoma
    Um. I recycled my old liner as weed barrier. Works great!
    May 2009
    Jasper, TN
    249
    I'll check into the fake mulch. I take it, it doesn't hold moisture like regular mulch?
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    If you have a Home Depot around or an Ace Hardware, they both carry the rubber mulch. Put a high quality weed fabric under the mulch so the water will drain away.
    Here is a link to Home Depot's product: http://www.homedepot.com/Outdoors-Ga...atalogId=10053
    Here is a link to Ace's product: http://www.acehardware.com/product/i...Id=47703856663
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
