Thread: New pump cant purge air bubble.
    Louisiana
    68
    I just bought a powerflo matrix 1HP and on the first run I noticed it won't evacuate all the air from the strainer. There is about a 5 in. diameter space of air in the dome shaped strainer cover when the pump is at rest and nothing I can seem to do to get it out. Is this a normal operating condition for this pump?
    11,000g, AG, aqua rite salt, Dough Boy 1.5hp, well water with some metal in it, and 2 beautifull oak trees that dump a ton of leaves into the pool.
    I use TF Test Kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: New pump cant purge air bubble.
    A smaller pump can have problems completely removing all the air but it should do so eventually. See what happens over the next couple of days and/or stop and restart the pump and see if it goes away. Also, make sure the filter is backwashed. What was the filter pressure with the old and new pumps?
    Mark
