Results 1 to 7 of 7
Thread: Nice site!
    Nice site!
    Greetings from the bluegrass state.....uh, Ya'll! I'm a kidney shaped gunite pool owner that inherited the pool with the house. We have lived here 15 years and the pool was built in the mid-late 1970's. I've painted it probably 3 or 4 times, replaced motor and pump (4 cartridge filter), Finally went with the salt to chlorine gadget instead of the chlorine and stabilizer route, and the pool has performed admirably every year. Now, I'm really sick of replacing the tiles that fall of of the strip every year so am looking for a solution in the under construction forum. Lot's of good advice and good ideas on here. The experience of some of the folks on here is invaluable!
    mrbillky
    16x25 Vinyl IG Under Construction - DIY
    Hayward Tristar 3/4hp
    Star Clear Plus Cart Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Nice site!
    Welcome to TFP
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: Nice site!
    Welcome! I'm sure you'll find the solution you're looking for here.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Nice site!
    Welcome to TFP
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Re: Nice site!
    Welcome to TFP!
    30,402
    Re: Nice site!
    Hi, Bill,
    Welcome! I saw that post in under construction and wasn't sure how to reply. I can't picture anything that would "fill in" or "replace" the void where the tiles fell off.
    What I can tell you is that they are falling off because they have not been installed properly. Most likely enough waqter is getting behind them, freezing, and popping them off. Tiles done correctly will stay on indefinitely regardless of the weather.
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Nice site!
    Welcome to TFP!
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
