Results 1 to 8 of 8
Thread: Filter questions
    Apr 2010
    Four Oaks, NC
    18
    Filter questions
    We have a Summer Escapes (General Foam Co from Walmart) 18x48 pool. It hold a little over 6000g. After fiddling with the existing filter all summer, I am upgrading to a sand filter this spring before I open it. I really wanted to work with a local pool company until I'm a little more sure of myself, so I have 2 options. The first is a 1.5 hp Pentair with a 18 in sand filter. I'm really afraid that this is just overkill. The other option is a 3/4 hp Hayward with a 14 in sand filter. The pool supplier told me this one was created to meet the needs of a smaller pool and all the fittings come with it. This one would turn over our entire pool in a little less than 3 hours and is the one I am leaning toward. I did ask if I decided to get a 24" pool if this one would work with it and was told that it would. I'm adding the Intex SWG while I'm upgrading. According to both companies, the filter is matched correctly with the pump.
    OK, so in my shoes, which one would you go with, the Hayward system or the Pentair? I have read so much information lately I'm not even sure where to begin anymore!
    18 ft round (Intex style) Summer Escape pool
    1hp Hayward pump and sand filter (size escapes me)
    Intex SWG
    Planning an upgrade to a 24ft as soon as we wear this one out!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Filter questions
    Unless the Pentair is a 2 speed pump that's way too much for that pool.
    I don't agree that the 3/4 14 would be big enough for the larger pool upgrade, however. But you could always sell the smaller one on Ebay or Craig's list to someone with an Intex looking to upgrade like yourself.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    just to clarify what FPM said, the 3/4hp pump is plenty big, but the filter's a little puny.
    Apr 2010
    Four Oaks, NC
    18
    That's pretty much what I was thinking too based on what I've read, but they won't let me put that pump on a larger filter. They said it would void any warranty because they would no longer be "matched". The Hayward was NOT a 2 speed.
    I think I'm going to go ahead and get the smaller of the two and upgrade later. Thanks for answering my question!
    Intex SWG
    Oct 2009
    3,899
    I doubt that it would void Pentair's or Hayward's warranty to put a small pump on a big filter. You should be able to call either manufacturer and get an definitive answer to that question, then bring it up with the supplier.
    I think you should get the right thing the first time, and my gut feeling is that the pool supplier is either ignorant or deceptive.
    22,553
    I can't see how it could possibly void the warranty. I'd really press for the 3/4hp pump and the 24" filter. I'm guessing that the pool store has combinations set up and doesn't want to break a set up. People are funny like that.
    I have a Pentair setup. It's a 1.5hp pump on a 24" filter and it didn't void the warranty. Call Hayward and ask them directly then you won't be guessing.
    Feb 2010
    Annapolis, MD
    46
    I think it is more that they are sold as a "package". When we were looking for a pool this Spring, NO ONE was willing to mix and match filters & pumps & pools. You had to buy the "packaged" deal. We settled on ours because I could get the 2-speed pump and a large cartridge filter with the pool. Other places selling similar packages would put you into a larger 1-spped pump or a sand filter and were unwilling to substitute other components.
    Frankly,I'd be buying a 2-speed pump and filter elsewhere.
    18' round, 52" deep Kamika/Nuance by trevi;
    1HP/2 speed Hayward pump/150 sq ft cartridge filter
    Aqua Trol
    May 2009
    Jasper, TN
    249
    Quote Originally Posted by KurtG
    That's why they invented mail-order.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
