Thread: Best way to trim a solar cover?
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    I bought a clear 16 mil cover. For the most part, the pool is a rectangle, except for one edge which is rounded inward.
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    Re: Best way to trim a solar cover?
    When I get my new one in, it will need trimming also. I was going to lay the old one on top of new and use a pair of good scissors.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    A friend of mine gave me a new one, uncut, after he figured out his pool was garbage. I laid it square over the top of the pool, and just started with an edge in the pool, flush. Scooted another edge in, and cut the 3rd edge. Final edge was a bit tricky, and kind of crooked. But it's just constant readjusting, to make sure it's not wrinkled anywhere. I was fairly pleased with the outcome. But yes, good scissors.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    Mar 2009
    eastern washington state
    i was told when they built my pool, is to put the solar blanket on for awhile before you cut it because it may grow in size a little or a lot.. and then you can cut it after a few days... they came back and did it and just cut it with scissors. works great.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Jan 2009
    Cupertino, CA
    Yep, mine expanded (de-wrinkling, warming up in the sun all day, whatever) and I needed to re-trim after a week or so. and over the winter it was clearly an inch or two short in the long direction. But it's easy to cut.
    BBB "Intermediate Swimmer"
    New Brunswick Canada
    Easiest way I have seen.
    Lay solar blanket out over whole pool area.
    Tape it off to deck, or place heavy weights on it and the decking.
    Grab marker, trace around the outside edge of your pool.
    Remove and cut on your line. Razor knife works wonders for getting a smooth line.
