Results 1 to 7 of 7
Thread: My testing number with my TF kit
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    let me start out with so fat my water has been doing great with the basic kit I got form the PB.
    My chlorine was around 2.8 when the pool store guy told me to super chlorinate with my SWG and raise the output from 10% to at least 45% as we are getting hotter here.
    Well, my TC test went to dark orange to brown after and I knew the water was messed up.
    So I ordered a TF-100 kit and here are my numbers today:
    FC 23.5
    CC O
    pH 7.4
    TA 110
    CH 325
    CYA 60
    Turned the SWG to 0% to get the TC down and will test every other day.
    any suggestions?
    Thanks
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: My testing number with my TF kit
    Quote Originally Posted by Hurricane Gio
    FC 23.5
    CC O
    pH 7.4
    TA 110
    CH 325
    CYA 60
    any suggestions?
    Thanks
    Wait.
    Knowing that you killed anything in the water ought to bring some peace of mind.
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by Richard320
    FC 23.5
    CC O
    pH 7.4
    TA 110
    CH 325
    CYA 60
    any suggestions?
    Thanks
    LMAO! I know that! Well, I gotta drain the pool a bit today from all the rain. But I will keep the SWG off until its normal again.
    BTW, the water is CRYSTAL clear!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yeah, just leave it off till it drops.
    In the future "superchlorinate" with bleach, you're swg cell will last longer.
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by frustratedpoolmom
    Even with a SWG? 2 different styles of chlorine wont matter?
    Mixing chlorine from bleach with chlorine from the SWG is just fine.
    The issue with shocking is that shocking is faster and uses less chlorine if the FC level comes up quickly. A SWG can't bring the FC level up quickly, it is designed to add chlorine slowly and steadily. If you have algae, the SWG and the algae go back and forth for some time before the FC level gets high enough, if it ever gets high enough. Using bleach you can raise the FC level very quickly, which kills the algae off sooner and with less total chlorine.
    Apr 2010
    Coral Gables, FL
    197
    Thank you from a Newbie! And people wonder why I became a Lifetime Supporter!
