Results 1 to 8 of 8
Thread: pump flow rate
    pump flow rate
    hey guys my pool has 2hp haywood pump it has a chart in the manual regarding flow rates according to pipe size, now i hav 2 inch pipe to the pump, out the pump converts down to 1 1//2 pipe entering the filter and back out and thru my swg converting back to 2 inch pipe for return to pool. my question is what pipe size on the flow chart should i go by 2in or 1 1/2 inch.
    12,500 IG Concrete Pebble Surface
    1 HP pump with cartridge Filter - Electric Heater
    4 Jets - Main Drain
    SW Florida
    South Central NJ
    3,192
    Re: pump flow rate
    2 HP pumps and 1.5" plumbing don't mix well. It will restrict the pump creating extra head loss. The 1.5" chart is what the flow will be.
    Scott
    Owner of - PoolGuyNJ LLC
    Re: pump flow rate
    There is much more to determining the flow rate than just knowing the pipe diameter. A calculator that uses only the pipe diameter and pump size won't be especially accurate. If it also uses the pipe length then it could be in the ball park, but there are still many many other factors that affect the flow rate.
    What matters for flow rate is the average pipe diameter, not the smallest pipe diameter. If the great majority of the piping run is 2" then you effectively have 2" plumbing everywhere.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: pump flow rate
    Normally, the flow rates listed in a pump manual are just pipe velocity recommendations and nothing more. What are you trying to do?
    Mark
    Re: pump flow rate
    got my salt level too high trying to determine how long i need to run them pump to remove the needed amount of water. followed what i thought was the right amt of salt to put in at fresh start up but i am up to 3900-4000 ppm. any dangers of leaving it thaT HIGH
    4 Jets - Main Drain
    SW Florida
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: pump flow rate
    Usually a SWG will shut off on it's own if the salt is too high. If it doesn't complain, then it should be ok. What model SWG do you have?
    Mark
    Re: pump flow rate
    i have goldline model
    4 Jets - Main Drain
    SW Florida
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: pump flow rate
    That unit should shut off if the salt level is too high. So as long as you don't get an error, the level is fine.
    Note too that salt level strips tend to read high so if you are going by that, I would see if the unit says the salt level is too high.
    Mark
