Results 1 to 9 of 9
Thread: Newbie with weird white cloudy water + mystery powder
    Apr 2010
    San Diego
    2
    Hello all
    Sorry if I don't include all pertinent information in my post... but
    I have a plaster pool (4 years since new plaster) aprox 10,000 gallons
    and every time I add liquid chlorine It immediately creates a weird white cloud. after that a white powder appears and coats the entire bottom of the pool.
    At one point it went unnoticed and it coated my entire filter with a concrete like substance
    Is this calcium in the water? I know our water here in San Diego is very hard, but no one in my area has this problem
    Any help would be welcome
    Doug in San Diego
    11,800 gal rectangle IG plaster/pebble
    Single speed, DE Filter NSWG
    Test strips and 2 way test kit(sorry)
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Newbie with weird white cloudy water + mystery powder
    Hi Doug,
    Welcome to TFP
    Please post a full set of test results and how they were obtained.
    Here's a link to Info needed to give the best advice.
    You're done SLAMing when:
    22,539
    As Butterfly said, we'll know a lot more if you can give us a full set of test results and how you got them. Read the link she provided and post back.
    Here's what we're looking for.
    pH
    FC
    CC
    TA
    CH
    CYA
    And any other you can provide.
    It kinda sounds like algae but we'll know more when we see the numbers.
    South Central NJ
    3,192
    Was this pool ever a Baquacil pool?
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2010
    San Diego
    2
    Ok guys
    Sorry for the delay - I only had a red and yellow test kit
    So Here are my test result from a 6-way test strip (not much better Im sure)
    Total Hardness - Off the scale high
    Total Chlorine - about 1.5 ppm
    Free Chlorine - Off the scale high
    PH - About 7.8
    Total Alkalinity - Off the scale high
    Stabilizer - Off the scale high
    No it was never a Bacquil ??? pool.
    My gut tells me I need to drain off some water and add new water.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by drierdan
    Ok guys
    PH - About 7.8
    I would guess for now since you only have strips, take a large sample of water to a pool store and have them test. This is not the best way either, but should be able to give you numbers. Do not buy anything they try to sell you. Come back and post the results and I am sure they can help you from there.
    I would suggest to get you a good test kit at home so that you can start to test on your own.
    I got the TF100 kit and it works great. You can pick it up here.
    http://tftestkits.net/Test-Kits-c4/
    Good luck.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    With both "Total Hardness - Off the scale high" and "Total Alkalinity - Off the scale high", you are probably seeing calcium clouding in the water and calcium scaling in the pool. To move forwards effectively you really need a good test kit, as others have mentioned. Once you have that, the first step is to lower your TA level down to something reasonable as soon as possible.
    Aug 2009
    North Central Texas
    1,358
    If it is calcium clouding the water it will take what seems like forever for it to clear up. Much POP needed. I had a lot, so much so that it took 24/7 filtering with my big new Quad 80 DE (using cellulose) for about 2 weeks to get it all out. It was a week before I noticed much difference. One morning I could see the bottom drain. And then it was significantly better each day. Took another week to totally clear.
    See this post. This was still how much I had after a week of filtering. Scroll down page to see video.
    http://www.troublefreepool.com/i-m-s...om-t18969.html
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
