Thread: Removing winter plugs from skimmer
    This is the first time I am opening the pool by myself. I have an inground pool.
    I am having a hard time removing the winter plugs from the skimmer. The plugs have a square top about one and a quarter inch. Is there special tool that I can use to unscrew these? I'm having a **** of a time trying to get a wrench in the skimmer.
    Any help is appreciated.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Removing winter plugs from skimmer
    Before removing both, are you sure the one closest to the pool isn't plugged normally during use? If you have a separate drain line back to the pump, that one probably stays plugged.
    Vice-Grips are about the best "make do" tool for that job.
    22,551
    Once you make sure which are supposed to be removed you can purchase a basin wrench to remove them. It's not a special tool just for removing plugs and it's dang handy to have around the house.
    Thanks Guys!!!
    A basin wrench did not work. I used my plyers to open up the skimmer plug one painful quarter turn after another. I not sure if the pool company cross-threaded the plug in the fall because man it was difficult to unscrew. The other plug for the main drain unscrewed with no problems.
    Darren
    What do the plugs look like? I have a male plug with a square part on top and what I guess is a female plug threaded into the pipe. Which one do I remove? How would you remove the female one?
