Thread: Pool pump cover.
    estrda1's Avatar
    Nov 2009
    Riverside, Ca. (SoCal)
    Pool pump cover.
    I was wondering if anybody has gone as far as covering their pool pump and or heater. My pump and heater take up an 8x8x5 footprint and was trying to clean things up in the backyard. I'm guessing an enclosed structure would probably b out of the question due to the heater exhaust. Any ideas what I can do?
    My 05/2016 resurfaced pool: 16ft x 24 ft irregular w/spa, 20K gal., gunite Stonescape Aqua White mini pebble. Not a salt water pool.
    Equipment: 3hp Intelliflo VS pump, Hayward C4020 4 cartridge filter, Hayward H series heater, Pentair Intellibrite 5g LED lights,Dolphin Nautilus Plus robot, TF100 test kit.
    Re: Pool pump cover.
    Heater requires 12' clear space from combustible surfaces, or 6 inches from non combustible, on the sides. 8' clearance to a "top".
    Pool equipment is made to be outside, so it is fine in that regard. An enclosure would be pretty tall if you are just trying to hide the equipment!
