Results 1 to 7 of 7
Thread: Compu Pool vs CIrcu Pool salt water generators.
    Hello all,
    I am contemplating putting in a simple SWG for my 22,000 IG Pool.
    I have located two models that may fit my budget.
    CompuPool Salt Chlorine Generator for Inground pools Up To 40,000 Gallons - CPSC36 - 649.00
    CircuPool RJ 30 up to 30,000 gallons- 779.00
    any thoughts? Does anyone have one of these models and do you like it.
    Pros and cons of each?
    Thanks
    Mike
    22,000 IG vinyl liner
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Jul 2007
    Brisbane, Australia
    874
    Re: Compu Pool vs CIrcu Pool salt water generators.
    it's the same generator, as far as i know
    JoshU's Avatar
    New Orleans, LA
    543
    Mike,
    Yes they are the same. I do believe the Circupool system comes a return jet fitting.
    I also sent you a private message about a new system coming out that is within your budget and it may interest you.
    Josh
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    The CircuPool RJ 30 does have a cooler color scheme
    Jul 2007
    Brisbane, Australia
    874
    Josh, care to share with everyone?
    Vero Beach, FL
    462
    I have the CompuPool. The Circupool has a few extra buttons on the control panel for doing a salinity test and for manual override of the pump.
    My CompuPool has been working great. But I do have a few minor issues. Low salt will cause the system to give erratic and wrong error messages. I'll sometimes get flow fault or high water temp readings when there is low salt. I think it is because there is no specific flow meter. Not sure how the system estimates temperature either, but it is never totally accurate. And to access the water temp or salt readings, you must enter the settings menu which means holding a button 3 secs and scrolling down.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Jul 2007
    Brisbane, Australia
    874
    keep in mind that it's a fairly new unit, i think it's been released about a year or two ago, so it will probably take some time to iron out the bugs like the ones mentioned above
