Thread: Tear in liner above water line
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    Hello all.....
    I have received a lot of great info and now I need some more. I just noticed a moon-shaped tear in the liner in one of the corners. The tear is about 3" long and about 1/5" wide at its widest. I am thinking just duct tape, but Im looking for a more aesthetically pleasing solution.
    Thanks in advance......so begins the early legwork of researching for a new liner
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Re: Tear in liner above water line
    Quote Originally Posted by rdkll
    Hello all.....
    Pool store sells liner patch...This comes in different colors to match the color of you liner...This is one of the things the pools store is good for. SO I would go that route...Duct tape might work...but the liner patch is more permanent.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    Thanks, thats what I'll do
    3) IG
    5) pump is 1.5hp
