Thread: switch wiring
    switch wiring
    I need to know how to wire 2 switches to control my spa and blower. I have 3 wire 220v going to my intermatic t104 timer. The white (hot) goes to #1,black #3 (hot), bare to grounding screw
    My pump,heater,and blower all run to #2 and #4 on timer. I want to be able to switch blower and pump on and off with different switches kinda like my heater. The heater has a onboard on/off swith so even when timer goes on heater wont start unless i hit the on button on actual heater.
    17k (430 Sq Ft) Salt Water In Ground Pool, 3.5'-7' depth, MDX2 Infloor system, Grotto/Tile Slide/Rock Waterfall Features, Wet-Edge Chilean Beach Tahoe Pebble surface, Intellichlor IC40, Easytouch Control w/remote, Pentair Clean & Clear Plus Cartridge Filter, Intelliflo VS-3050 Variable Speed Pump, 2 x intellibrite LED Color Lights
    22,550
    Re: switch wiring
    Clarify things a little for me and I'll see what I can do to help.
    Do you want to be able to turn the blower and on and off regardless of whether the timer is on or not?
    Or, do you just want to turn the pump and blower off and on only if the timer is on? (this is easier to do)
    Do you want separate switches for the pump and blower?
    Re: switch wiring
    Yes, i would like to be able to turn off pump and blower with separate switches and only if timer is on.
    22,550
    Re: switch wiring
    That makes it a lot easier. First turn off the breakers feeding power.
    All you need is a manual motor starter for each unit. Some 12/3 awg wire, conduit and a double box or two single boxes with weather proof covers.
    Mount the box(es) in a convenient location.
    Mark and remove the wires going to the pump & blower from terminals 2 & 4 & ground.
    Remove the conduits going to the blower & connect them to the new box(es).
    Run new conduit from the timer to the new box(es) and add two pieces of the new wire.
    terminate the black wires on terminal 2, the red wires on terminal 4 and the greens to ground.
    Hook all the gounds together in the new box(es).
    Hook one pair of the black and red wire from the timer to one of the switches.
    Hook the other pair of black & red wires from the timer to the other switch.
    Hook the wires from the blower to one switch.
    Hook the wires from the Pump to the other switch.
    Install cover(s).
    Re: switch wiring
    Worked like charm. Is it possible to pull a 110 outlet always on from from timer or switch?
    22,550
    Re: switch wiring
    Technically, yes, but I don't recommend doing it since you don't have a separate ground you'd be running an old two wire 120 volt system. In an outdoor setting that's a big no-no.
