Results 1 to 7 of 7
Thread: Can I use Boric acid from a pottery supply company?
    Jul 2009
    Seattle, WA
    89
    I think I just found a deal on Boric Acid in Seattle.
    The webpage (www.seattlepotterysupply.com) doesn’t say much about their boric acid except that it is $33 for 25lbs. So is there anything I need to confirm when I go to the store?
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Can I use Boric acid from a pottery supply company?
    I looked, but was unable to find boric acid listed anywhere on the site. Do you have a specific link?
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    here you go...you may try e-mailing them first
    http://www.seattlepotterysupply.com/...ory_Code=RMPAC
    Jul 2009
    Seattle, WA
    89
    I intend to call first, at the very least I want to be sure they have enough in stock. I just wondered if there is anything else I should confirm before I dump it in my pool.
    I imagine that all of their info about the stuff will be pottery related and they'll just look at me funny if I sayI want to swim in it.
    You want technical grade, or laboratory grade, boric acid. It should be 99+% pure.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    If my numbers are correct boric acid at $33 for 25 lb is more expensive than borax - at least around here. 20 mule team borax costs $2.98 for a 4.75 lb box at my local Wal-Mart. If my formula weights are correct (61.8 for boric acid and 381.2 for borax) the cost per lb of boron is $7.76 for the boric acid and $5.71 for the borax.
    Mar 2007
    San Rafael, CA USA
    12,082
    Don't forget to add the cost of Muriatic Acid needed to compensate for the rise in pH from Borax. Boric Acid is only slightly acidic while Borax is very basic. When you factor in the cost of the acid, the prices are much closer -- the boric acid may even be a little less expensive.
    For 10,000 gallons, to get to 50 ppm Borates compare the following: 23.9 pounds of boric acid vs. 36.8 pounds of 20 Mule Team Borax plus 2.2 gallons of full-strength Muriatic Acid (31.45% hydrochloric acid).
