Thread: Lowering TA
    Feb 2009
    NW Chicago Suburb, IL
    75
    Lowering TA
    Do I have to lower my PH all the way from 7.6 to 7.2 to have an effect on TA?
    I would feel more comfortable bringing it down to say 7.4 and then aerating to bring back up and then repeat.
    However, I don't want to go the effort if that swing won't really lower my TA
    FC 5
    CC < .5 (just ever so slightly turns a very very light pink when doing the test)
    PH 7.6
    TA 130
    CH 240-270
    CYA 50
    Salt ~3000
    Thanks.
    15,000 Gallon IG 15x30 fiberglass
    CoverStar auto safety cover
    SWG Aqua PL-PLUS
    Cartridge Filter
    240,000 LXI Heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Lowering TA
    Adding acid is what lowers TA. In theory, you can lower your TA just as rapidly by shooting for 7.4, it will just take more frequent additions of a smaller amount of acid.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Lowering TA
    It won't hurt to lower it to 7.2. The SWG will make it the pH rise fairly rapidly, so don't worry about it. Just use the Pool Calc and make sure you are confident that you are determining the amount of acid correctly. IF you aren't sure, just post back and we'll confirm it for you.
