Thread: Adding cellulose to a sand filter
    Jul 2009
    Seattle, WA
    89
    I’m not unhappy with the sand filter, just greedy for even better water.
    Thanks to you guys, there were days last summer when the water was so clear that I had trouble telling what the level was by looking across the pool at the skimmer. But I feel like unless carts and DE are over rated I could get there faster and maybe even farther if I added some DE to my sand filter.
    However, since my 4-year-old likes to help with the pool I don’t feel real warm and fuzzy about using real DE. Plus my backwash line is plumbed to the storm drain that may or may not be treated before it dumps into the ocean so I am not even sure DE would be legal. Would anyone care to share their experiences and/or opinions Cellulose or “Fiber Clear” (probably the same thing)? Are there any others I should consider?
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    Re: Adding cellulose to a sand filter
    I use Fiber Clear and it works amazing! My water gets super clear after I use it.
    I used to use real DE and fiber clear definitely works as well. I'm not sure its any better, but it is sure not any worse.
    32' x 15', 25k gallon gunite IG pool, California Quartz plaster in Tahoe color
    Pentair equip (Intelliflow VS+AU pump, DE filter, IC40 SWG)
    Spa wall removed to make "seating" area
