Thread: Wait did I just buy the wrong test kit?
    May 2009
    Sweet Home Alabama!
    7
    I logged on early this AM and bought the mini TF test kit because I already have the standard Walmart Chl/PH test kit. But while I was doing dishes this morning I had a sudden thought-- isn't the general consensus here that the Walmart Chlorine test kit doesn't accurately show above 5 ppm (which mine doesn't other than turning the brown/yellow color of course) and that this is not a reliable way of making sure I've reached shock level?
    So I'll get my new shiny test kit but I still won't be 100% following the rules around here for getting my water clean because I won't truly be sure of my shock level. . .
    Is that right or do I need more coffee?
    Nicole
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Wait did I just buy the wrong test kit?
    Hi there,
    If you bought the TF-50 you will be fine....
    May 2009
    Sweet Home Alabama!
    7
    Well I did but here is the part that concerns me:
    It does NOT contain the OTO chlorine test and (this is important) it assumes you already have a pH test. If you do not already own a pH test, this kit may not be a good value for you. That said, you can always go to WalMart or a Pool Store and buy an inexpensive pH and OTO tester (around 5-10 dollars) and your needs will be complete.
    My Walmart test only measures up to 5 ppm. . .
    11,969
    The TF-50 does not contain the OTO and PH test that are in the Wal-mart Test kit. The TF-50 DOES contain the FAS-DPD test, which can test chlorine up to 50ppm. You'll be fine.
    May 2009
    Sweet Home Alabama!
    7
    Thanks!
    30,421
    Confirming FPM's reassurance, you are good to go....that's exactly what the kit is designed for.
    (it shipped an hour ago )
