Results 1 to 12 of 12
Thread: May need to borrow previous posters handgranades
    I am having significant problems maintaining pressure in the pump and circulation system. The water level seems okay..there are no leaks in/around the pump housing. I've resealed the pump basket lid and yet I still get air into the system. It pumps fine and this about every few minutes the waterfall and all jets will quite working...then it immediately picks back up again. What else can I check or do...?
    Grant and Jerri
    Liberty, NC
    New 18x36 vinyl liner pool with lighting and fountain
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: May need to borrow previous posters handgranades
    Check your skimmer, make sure it isn't making noise or there isn't a vortex in the water.
    Check any unions or valves before the pump basket and check the drain plug in the pump basket.
    Any drips of water when you shut the pump off?
    define vortex in the water
    Grant and Jerri
    Liberty, NC
    SW Indiana
    9,198
    Quote Originally Posted by GrantsPool
    Whirlpool
    A vortex is what you see when a sink drains. The issue here is that there is usually air in the center of the vortex. The air gets drawn down into the pipe and heads to the pump, where it can cause problems. If this is happening, raising the water level half an inch or an inch will generally take care of it.
    Jan 2009
    Cupertino, CA
    1,966
    I've also heard of people dropping a tennis ball or something into the skimmer, to break up the vortex. If you have one.
    --paulr
    BBB "Intermediate Swimmer"
    I was watching the skimmer yesterday (apparently that's what us pool people are suppose to do)... anyway... the water level stays high and consistent...then you do get the vortex type movement and all the water drains, the waterflow stops and the basket refills... then it runs again for a while.
    Grant and Jerri
    Liberty, NC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Is the flapper on the skimmer sticking?
    Something's not keeping the skimmer full.
    flapper seems fine... casual observation suggests it is at the pump
    Grant and Jerri
    Liberty, NC
    Richard320's Avatar
    Jan 2010
    18,967
    Not if the skimmer basket empties! We are talking about the same thing aren't we? The skimmer is in the side of the pool. Or are you talking about the pump basket attached to the motor?
    Vero Beach, FL
    462
    Looks like you found your problem. Intermittant loss of pump head like that tends to be from the skimmer. Other types of suction side air leaks, like pump basket cover, couplings, etc. tend to let a continuous stream of air into the pump.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    SW Indiana
    9,198
    Put your hand in there and hold the weir down flat and see if it keeps doing it. No matter what your pump is doing, it shouldn't be able to empty the skimmer. Almost has to be the weir.
