Results 1 to 14 of 14
Thread: Economy Improving? Contractors not showing for estimates
    Feb 2010
    Annapolis, MD
    46
    I'm guessing that the economy must be on the turnaround as far as home construction goes. I'm having trouble getting estimates (having contractors show up) for electrical work that involves running service to our pool pump (~$1500).
    Any others having similar problems in your area?
    18' round, 52" deep Kamika/Nuance by trevi;
    1HP/2 speed Hayward pump/150 sq ft cartridge filter
    Aqua Trol
    Vero Beach, FL
    462
    Re: Economy Improving? Contractors not showing for estimates
    Not for our pool, but some other home remodeling work we wanted done. I called 4 places and only 1 guy bothered to even return my call. And the construction business has not improved here yet.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm about to remodel my kitchen, and I'm told by those I've been dealing with that they are very busy, folks are 'fixing up' instead of moving out, and prices on cabinetry and granite are at 10 year lows. Maybe this is carrying over to electricians in general? (got one coming over this afternoon
    Feb 2010
    Annapolis, MD
    46
    Good luck I had no shows yesterday for scheduled appts and not even a call.
    Aqua Trol
    I've been having the same problem with getting our pool fence installed. I've been through 3 companies so far that have scheduled and rescheduled atleast once apiece to install this fence and another that is supposed to come out today after being re-scheduled now for the third time. Apparently, making $3000+ on a day's work isn't high on their priority list!
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Fish must be biting.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    11,969
    Quote Originally Posted by Lershac
    Golf course is calling
    Guest
    Actually, their is no excuse for not showing up (or calling) to change or to cancel an appointment. If they don't have the courtesy to make contact, then I would never consider them! Just my two cents!
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by denisbaldwin
    Several years ago I had similar problems with independents, for a couple of months, for about 60 ft new section of wood fencing/steel post that ranged in height from 6 to 10 ft (so it would be level across top). To get the height we had to go to pine instead of cedar. I finally went through Home Depot and the job was started and finished in no time. Excellent quality materials and workmanship. They even did something wrong and had to tear out some of the work and several posts with no argument or complaints. This was an independent contractor who did the job but "driven" by Home Depot's customer satisfaction factor.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Dec 2009
    Central Massachusetts
    2,690
    It's hard to get anybody to call you back. Last year, whenconstruction was dead slow, I called 4 blueboard plaster guys to do about 1000 sq ft in my basement. Only one guy called me back. He got the job. One day job, 3 guys, 13 ben's! Easy money, but only one call back.
    Called a guy out for an estimate on a fence. Bout a 5 k job. Never showed.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2009
    North Central Texas
    1,358
    When I was seeking bids for my fence I think I got about 5 call backs, only two showed up for estimate, but neither got back with me on estimate. Subcontractor from HD called immediately, was out here within a day or so, and by end of week job was finished. I don't know if they were cheaper or more expensive than independents would have been. At least I didn't waste any more time making calls, waiting for call backs, or waiting for no shows. Even though I work from home most of the time the distraction of anticipating someone to show up, during a time block, is too distracting for me to get any work done. And they frequently don't come during the "time block" even if they do show up.
    Although many people have bad experiences with AHS I have always been able to count on the workers to show up, usually during the agreed upon time block. That's "priceless" to me.
    gg=alice
    I find it humorous that an hour after I posted about them not showing up, they arrived and started putting up fence. They're about half way done! Should have photos later today.
    Clearwater, Florida
    I'm a contractor (Custom Garage Makeovers) and I have been 3-5 weeks out on all projects for about 5 months now. But I always return calls and have never not shown up for a set appointment to take measurements and get a proposal to a customer. My business has not really slowed up, it actually has been going crazy since the first of the year as I am seeing alot of people wanting to stay where they are and improve and upgrade the homes they are in. I also have a couple of new construction projects under way (one is a 12 car garage 3500 sqft) so new builds are also picking up some here in our area.
    I don't do many of the home remodels at my own house, I just don't have the time and in most cases the expertise to do them the right way in a timely manner. We are going to remodel the master bath and I'm not a plumber or a tile guy, though I can do both, but again I am not the day to day expert on these trades so I leave it to those that do it everyday.
    If a contractor does not show up for an appointment or does not return a call for days on end I tell them straight up they lost the job based on that, maybe they will learn from the experience. If I lost a job because I lacked a certain business skill set I would appreciate a prospective customer bringing it to my attention so I can not make the mistake again.
    23000gal. IG free form with waterfall
    mini pebble interior midnight blue w/Tahoe blue plaster
    OK flag coping, moss boulders and Idaho Quartz flag in waterfall
    Hayward SWG, Hayward 2-speed 2.5hp pump, Prologic Goldline Controls, DE 60 Filter,2-Hayward LED Lights
    2 skimmers, 8 returns 3.5'-8' Deep,Pool size 19'w x 36'L Salt version diving board,Polaris 480 Black cleaner
    Jun 2007
    North Florida
    79
    "Our" electrician is also MIA. We're sorta new in town and got a recommendation from the city's permit office based on who does most of the work on this builder's homes....even though the home was built over 10 years ago. But this is a smaller town and there's not a whole lot of residential construction going on to keep the construction trades busy.
    Got them out for an estimate fairly quickly back in March. Nice enough guy came out and seemed to be writing a lot of notes and suggesting one thing or another as we went along. Nothing after that. I called them in early May to say, "Excuse me, but is our estimate ready?" The receptionist was quite nice, took my name and property address, saying someone would get back to me. No one ever called me back.
    Believe me...if anyone in town asks about electricians, I'll be offering my 2 cents on the company!
    Sandy
    15,600 gallon, screened 15 x 30 sport pool with 6 x 8 baja shelf, IG plaster (Diamondbrite??), Hayward cartridge filter, 1-HP Hayward pump, Hayward/EUS Mark VI heat pump, Polaris 280, AquaRite SWCG
